Just a quick update.. the boss was in Canada for 3 weeks so I bit the bullet. £250 on bits, did a full service on the bike - airfilter plugs etc - and master and slave clutch kits. I did the master first - no change and then the slave.
It took a couple of days as I don't have a lot of space in the garage and it take me 5 mins to get off by back to stand up as kneeling is not a function I can do these days.
Anyway - as everyone says, it not technically difficult - its just awkward (slight understatement as I'm polite).
Clutch now sorted.
Lessons learned..
1) I delayed doing the clutch slave for 2 years. If you have the same symptons, don't hesitate, JFDI.
2) Make sure you've a 1/4 drive set.
3) Long ring hinged Ratchet 12mm for the banjo.
4) A little helper - to pass you the correct size socket once you you spent 5 mins trying to youself in the correct position with the wrong one on the end of the drive.
5) Take you time, don't rush it.
6) Find all of you tools BEFORE you start the job!!
7) Clean underneath the bike with a jetwash - with the tupperware removed.
8) get some wd40 on the front lower radiator cowel screws they are a complete bar steward to remove - I had to resort to a bit of heat from my tiny gas torch to free them off.
9) Get some else to do it
Good luck
Thanks to all for the advice, hints and tips - at the end of the day, its another ST1300 A9 on the road again
PS - the abbreviation JFDI means "Just Do It"
Live long and prosper
Joe - Sunny Newcastle, NE England, Planet Earth.
