A little different perspective for consideration.
Everything on the above list, with the exception of the first line, I consider to have a high degree of probability that they will need to be done on any used ST that is purchased. These are known issues that need to be dealt with on any used ST1300, the exception being those that have a combination of very low mileage and/or proof of scheduled maintenance having been meticulously accomplished. Those types of ST1300's exist, but they are not always available when a person is in the market, and they usually command top dollar. For that reason, I would take all of those items off of the list of strikes against purchasing this motorcycle. These items would have to be considered as potential required maintenance expenditures that will need to be done to any other used ST that might be looked at as well. In that sense, this one is no better or no worse than any other used ST1300 that you might be considering, as it will have the same degree of possibility of needing these same repairs. That kind of levels the playing field, leaving only issues with this motorcycle that are not considered routine to analyze and decide how they influence this as a potential purchase.
That leaves the electrical issue to be decided upon. From your description, it sounds like a ground fault. That is something that is easily fixed even if it might be difficult to find. If that is the case, you will have found a good motorcycle at a ridiculously low price. The considerable amount of money that you stand to save on the purchase price will cover the cost of any routine repairs and maintenance items that are normally needed on any used ST1300 that has accumulated average mileage. You would most likely have to spend at least some of that same money on any other used ST1300 that you might purchase on top of a much higher price.
A recommendation to purchase this motorcycle or not can not be given as we can not evaluate it. What I am suggesting is that this electrical fault, based on your description, is probably easily fixed. This purchase should be evaluated based upon the condition and merits of the whole motorcycle, the same as you would evaluate any other potential purchase. It should not be disregarded simply because of the electrical issue. If the rest of the motorcycle appears to be a good purchase, then you must decide if you want to tackle fixing the electrical issue. If you do, you quite possibly might end up with a good ST1300 for a ridiculously low price.
