My bad,,, I mistakenly entered a file photo (from the cbr1000 forum,,, I think), that definitely shows a burned yellow grounding block. I have edited that photo out of my post,,, and replaced it with a shot of Blue STars yellow block. Here is the correct photo's,,, and thanks for catching my mistake,, cheers,,, CAt'The left side of the yellow connector for grounds definitely has been hot... the metal clip is discolored, and the yellow plastic cover was melted to it, that's why you had a hard time getting it open. Resistance is causing the heat, you may be able to clean it and lower the resistance, or do the replacement as others have discussed. Basically, if you are melting plastic, you have a bad connection. There may be other areas bad as well, but you do need to address this spot.
ps: I promise not to do late night posts without my reading glasses in future,,, sorry for any confusion
