Larry LOVES the stuff.Great video ( turned the volume down) and a lot of good info from that and from you folks - I used Marvel Mystery Oil in my now deceased BMW R90/6 for top end treatment (in the air cooled Lycoming engine in the plane as well) and wonder if any of you ST1000 guys have any thoughts on using MMO in your bikes?
I've seen naptha in cans (quart?) at paint stores in the solvent section. Not sure how pure it is.Pri-G is another naptha/Stoddard Solvent based product..... Seafoam might be cheaper by the gallon but you can usually find the smaller cans on sale for about same money overall as the gallon. Probably even cheaper if one can find pure naptha.
Shell responded to a reporter's question about this that at their average self-serve pump set-up there is only about 1/2 litre (1 US pint) of fuel that remains in the system between the mixing valve and the nozzle. If that is accurate, a person would have to be buying a very small quantity of fuel for this residual amount to have any influence.you are getting what the person ahead of you purchased as much as gallon of fuel.
Good common sense advice.Not sure if I'm learning much, kinda hate the hype ..... First I would never have anywhere near that much water in fuel, just use fresh fuel, too obvious. Maybe that was more useful for those that use E85, don't most of us know already that stuff is bad? We know non-ethanol gasoline itself doesn't go bad for a long time (the experts say 1-2 years), but if it gets the opportunity to evaporate, there will be a gummy deposit left behind.... which is why you drain your carbs before storage. If you check the MSDS of many stabilizers and fuel conditioners, they contain naptha (slow-acting solvent that dissolves gums). Seafoam also contains isopropanol, a different type of alcohol that actually can take care of water really well, whereas ethanol is saturated at 4.5% and you get "phase separation" if the water level exceeds that. In a humid environment, that may take place in less than 2 weeks.
So basically to keep it simple, fresh non-ethanol fuel for storage, Seafoam as your stabilizer, and drain your carbs. Now if someone wants to debate the evils of ethanol for the economy and what it's really costing us.........
yeah... if you do the math, there's max 20 feet of hose/pipe back to the pump, 5/8 ID..... besides you really dilute it with a fillup... go fer it.!Shell responded to a reporter's question about this that at their average self-serve pump set-up there is only about 1/2 litre (1 US pint) of fuel that remains in the system between the mixing valve and the nozzle. If that is accurate, a person would have to be buying a very small quantity of fuel for this residual amount to have any influence.
