After working flawlessly for a couple of weeks my FCE also started to act up. Accelerating from 3,500 rpm nothing would happen for a few seconds and then the engine would catch and the bike would accelerate normally. The bike acted as if there was water in the fuel. After adding some water remover to the gas and running the tank to almost empty I refueled at a different station but the problem persisted. After seeing some of the recent posts with similar symptoms I removed the FCE and the problem disappeared. I contacted Ivan's and my FCE is on it's way back to them for testing.
A couple of things I did notice: the problem seems worse when the outside temperature is extremely hot-I wonder if one of the components within the FCE are failing at high temperatures?
-When the FCE is working correctly the heat from the right side is definitely lower. When it is malfunctioning the hot air just pours out from the right side-even worse than with no FCE.
I hope that it is just a case of a few bad units early in the production process because when it works it is a real improvement over stock.
