Re: Fuel Cut Eliminator for ST - On-Off Throttle Issue Resolved
I guess I'm a 1%er, too. Sure seems like there's alot of us. I have Staintunes, Turbo Tom's FPR set to 59psi, Tom's modification to the air box for better breathing, and a K&N filter. I've also taken up the slack in the throttle cables. No G2.
I'm probably not a candidate because I don't like the idea of cutting into the computer cables. Now, if there was a way to connect it like a Speedohealer where you just disconnect a bullet cable connector and plugg the male end into a female wire end and vica versa, then I could see it as it would be semi-permanent and waterproof. I haven't looked at the computer recently, but I believe the wires into it are 'hardwired'. I could be wrong and probably am as, now that I think about it, if the computer goes bad, you don't have to rewire the entire system. So I could see pulling the wire bundle bracket connector and connecting it to an equivalent one from Ivan. That's not cutting and splicing, that's just unplugging and plugging.
Still, I'll await more reports from peoplle with farkles using the FCE.
