Fork Fluid Leak?
wjbertrand
Ventura Highway
Ventura, CA
It worked!
Just used a small screw driver to stretch the dust cover...<snip>...
:eek: Next time don't touch the tube with anything like a screwdriver, lest you create a ding or scratch on the fork tube that damages the seal and starts it leaking again. This time a seal saver won't help. A much better practice would be to pry the dust seal up out of the lower leg and then slide it up out of your way and keep hard tools away!
Central Oregon
1997 ST1100
8440
I dont clean out the seals after every ride. Just after noticing a leak.
A total seal blow out this will not solve...a small leak it may. Most small leaks dont loose a lot of fluid. Just enough to collect some dust around the seal area.
x2 on not prying on the dust seal just pop/slide it up out of the way!
Northern Indiana-Merrillville
Glad it worked! I always pry the dust covers up then clean the area real well under the dust cover, then do the negative trick.
Sometimes the leaks come back...sometimes they dont!:biker:
Yes it came back after a long ride in the rain, I,ll pull both them apart and replace seals,bushings, and fluid when I get back home.
I see an issue with the 'clean the debris out' method.
By cleaning after every buggy ride you'd keep them clean; but, I don't think cleaning after noticing a leak will keep your forks working properly.
Now you do not know how much fork oil is in the fork...
Yes I thought of that I was just hoping I wouldn't half to cancel the trip to get parts to fix it right.
