A couple other things that should be inspected, are the pads themselves. Are they OEM Honda? or Aftermarket? EBC etc.
If they are EBC, these could be causing fitment issues, as the EBC front pads are too thick, and will not allow the caliper to back away from the rotor.
Honda uses thick pads on the rear, and thinner ones in the front calipers etc. EBC chose only to use the same thickness on both pads, and this has been known to cause issues with dragging brakes etc.
EBC also chose to leave out the heat shield on the rear pads, causing the fluid to degrade faster etc.
You should also check the rear caliper mounting bracket to make sure the pad retaining pin is firm/square and not worn away at the bottom edge allowing the pads to tilt ever so slightly, causing bind on the guide dowel etc.
Several things must be checked/inspected in the brake system.
If the piston didn't move freely before pushing and pulling on it, but it now moves more, that probably means that the piston is stuck down inside the bore a bit, and was just forcefully moved etc.
The pistons should not move more than 1-2mm. If you've got 3-4 mm of free play, that means the piston is stuck down in the bore etc.
The piston should be under both spring and hydraulic pressure, and should not have any dead space in its stroke, unless something is wrong, such as air in the system, binding, damaged SMC etc.
The needle bearings could be dry and binding...
The spacer on the upper SMC attachment point could be damaged and folded over, causing binding....
The return inlet port and filter/screen cartridge is clogged and not allowing fluid to return, thus building up pressure behind all the pistons, causing things to bind....
The counter sunk head of the the lower SMC pivot bolt (think bearing surface) is dry and binding....
The rubber boots in any of the calibers are swollen and binding....clips dislodged and dragging/binding....bent clips....damaged/dry pad retaining pins...the O-ring on the end of the pad retaining pin(s) could be damaged/torn/missing, causing binding.....
Too much grease/lube on the guide dowel...yup, causing binding...
Rear wheel assembled incorrectly (sequence) stopper bolt needs to be tightened before the axle nut or it will cause binding....
Stopper bolt loose, pinching down on the rear brake line hose....etc.
Someone used spray brake cleaner to clean the calipers, and its causing the seals to swell and drag the pistons....
The seals are dry/dirty binding....
The seals are worn flat....binding.....
Dirt behind the seals etc....binding...
If it were on my table, I would carefully start inspecting EVERYTHING and try and find the cause of the problem, instead of throwing solutions at a problem...
I'd probably be reaching in my parts cabinet for a replacement secondary master cylinder, 4 oil lock washers, and some fresh Dot 4 brake fluid....AFTER, I inspected everything.
But that's just how I roll....or spin...or not drag....
