I'm still undecided about whether to buy the TPMS (Tire Pressure Monitor Sensor).
I have the Garmin TPMS sensors for the 595 and I am very happy with them. The setup is easy and only has to be done once.
The sensors use an uncommon battery size. You have to be careful when buying batteries to ensure that they are "fresh" (meaning, they haven't been sitting on the shelf for 10 years). The first year I had the sensors, I went through 3 sets of batteries and was pretty annoyed - I thought the sensors were eating the batteries. The next year I bought batteries from a different source and they lasted a full year.
I think it is worth the money to get the sensors - they provide a lot of peace of mind, and you don't have to constantly be crouching down at the tire, getting brake disc dust all over your hands while checking pressure with a gauge. I suggest that when you set the sensors up, you set the trigger point (warning point) 4 PSI below your target value - this way, you won't get nuisance warnings if you park the bike outside and it gets cold overnight.
An unexpected benefit of having the sensors is very early detection of small leaks, and the ability to rapidly assess the rate of leakage. The GPS will display a low pressure message at startup whenever a tire pressure is below the trigger point. So, if you have a small leak that is losing 1 PSI per day, you will figure out the leak rate pretty easily after 2 or 3 days.
Another benefit is much improved awareness of tire pressure changes due to significant changes in the outside air temperature. A few days ago, I rode from Georgia (80°F when I left) to Toronto (39°F when I arrived), and I was given a low pressure message after a meal stop just before crossing the border. The tire was at the correct pressure leaving Georgia, but when it cooled down (after being parked) to 39°, the pressure had dropped about 3 pounds. No leak in the tire, the drop was due to ambient air temperature change.
I believe that you need to use metal valve stems if you install the sensors - go to the Garmin site and download the instruction manual for the sensors before you buy them.
Michael
