Hi All,
I have a 2007 ST1300A and recently had a problem where the front left hand caliper detached from the bike (dont ask) resulting in me having no breaks but having to use what i did have until they failed completely.... The result, rebuilt the SMC with new parts, the screen filter is clean and the port free of blockages, rebuilt the master brake cylinder fitted new pads and have bled the system according to the Honda process steps. The calipers were all serviced in December of 25 and were working perfectly prior to the event. When i was fitting the new pads i noticed that as i pushed a piston in (centre) the two outers on the rear caliper would come out and vice versa. Fitted the pads all round and both the lever and the pedal felt good. However, after depressing the rear brake pedal the rear wheel is solid and does not rotate, if i crack the outer bleed nipple the wheel will turn. the fronts wheel is also binding slightly. I have never experienced this with a bike before but have with a car where the flexible brake hose had failed and would allow fluid to go one way but not return creating the same issue. Any advice on how to identify which pipe could be causing this as im guessing it could be any given the interlinked nature of the system would be appreciated. Another thing to note is that when the brakes failed the front brake leaver went solid and the rear pedal just traveled to the lower point. I have throughly bled the brakes and am sure that there is no air in the lines.
Thanks in advance
Stuart
Thanks in advance
Stuart
