I have an '06 in which I replaced the original battery with a new Yuasa about 18 months ago. During a 3-day ride last weekend, I went to start the bike, and the battery seemed like it was weak ... slow cranking, and my tripometer & MPG readings zeroed out, too. The bike did start, and has been starting OK since then ... well, that is until this afternoon.
After about an 8 mile commute from work in 85-degree humidity, I stopped for about 40 minutes to get a haircut. The bike started fine when leaving there (I would say I was leaving the barber shop, but it was a beauty salon ... the same gal has been cutting my hair since 1986 & she now cuts my wife's too), and I rode another 3 miles in stop-n-go traffic to my favorite Ace Hardware store. I was in there for 5 minutes tops. When I came out, I got the WHIR-whir-clik-clik-clik-clik ...
Everything is flat here along the right coast of VA, so there's no place to attempt a downhill push-start. Besides, it's hot and humid today. I'm only a couple miles from home, so I walk there to get my SUV. I get back to Ace ... hook up the jumper cables ... starts right up ... reinstall the right-side panel, sidecase & seats (yes, I have extra bike keys) ... lock up the loose stuff inside my SUV ... ride the bike home. Mrs. Hoowasat took me back to Ace later to pick up my SUV.
Back home again, and try the starter ... several times. Starts right up each time ... cranking faster than any other time today. So I'm wondering if I have a loose connection (I know I have a screw loose in my noggin) ... and other than checking the cable st the starter motor, I'm wondering if others have found another common location where I might find something not up to par. The battery connections are already confirmed as secure.
I'll dig into getting at the starter this weekend. The service manual says I need to remove the rear sub-frame (seat rail) and lower fuel tank to gain access. If all I want to do is check the cable connection, I hope that can be accomplished without disassembling half of the bike.
So, have any of y'all found a common loose connection somewhere? And do any of you know if snugging the starter motor electrical cable connection can be done without major disassembly?
Thanks in advance! <Ken>
