moly paste
Louisville, KY
2021 R1250RT
Received TS-70 moly paste today in advance of tire change. Is 5 grams really enough for the splines? That's what is in the manual. The white plastic lid the paste is in weighed 3 grams.
jfheath
John Heath
Ilkley, W Yorkshire, UK
2013 ST1300 A9
000679
2570
5g is exactly what the manual calls for to be applied to the joint surface of the splines in the final gear case and on the driven flange - ie the female and male parts respectively.
Is that what 5g looks like ? It looks to be a lot.
What is that in term of a standard fingerfull ?
Montreal
2009 ST1300A9
That is plenty. All that is needed is enough to make sure that all of the metallic surfaces are fully coated.
Anything beyond that is not providing any additional protection.
Louisville, KY
2021 R1250RT
Yes that is 5g weighed. I guess it depends on the finger lol.
You have more than just the splines to cover.
Check/inspect under the spline plate, and replace both of the o-rings as well.
