pre 96 swing arm on post 96 bike?
Ireland
Tried searching to no avail...
Can a, say 1993 swingarm go on a 1998 abs bike? any difference in them?
Many thanks
Ireland
cheers guys.
Have a corrosion issue, but option of a secondhand one...
Incidentally, when they corrode is the inside plate likely to buckle enough, so the drive shaft "scuffs" a little inside the torque tube?
I can see a little scuffing inside the tube section.
Ireland
I'd say you'll miss some mounting tabs for the ABS plumbing...
If you can refab those (reliable and in a way you'll pass a tech inspection)...
yes. was thinking that's the only difference. rubber pad and a tie wrap will do.
Not so sure if drilling and tapping holes is a good idea
Some tabs are spot welded, some clips (on the cross member) fixed with M6 bolts at factory.
I'd choose large, quality zip-ties though... (don't want to end up with a brake line rubbing anywhere)
Bearing stock, f/drive flange, etc... are identically...
A much better project then trying to weld up the corroded and rotten old swing-arm; heat/cool contractions will warp the legs all over the place (unless you've a massive jig), patches on the outside won't do it, as they're rusting inside out (due to that notorious winter usage)...
So don't forget using some quality cavity conservation on the "new" part...
Some visualization:
Wisconsin
1994 Honda ST1100
not sure if information still needed regarding the swing arm but all swing arms are the same up to 2002. The 2003 ST1100P (police) is different.
