rear bearings st1100 ,93
Netherlands (utrecht)
I want to put new bearings on the rear wheel but the distance collar is in the way so i can,t at the back of the bearings to hit them out.
How can i get the collar out of the way???
West Michigan
'98 ST1100
8470
Move the spacer over. You can then catch the edge of a drift, or use a 1/2" extension female end.
jfheath
John Heath
Ilkley, W Yorkshire, UK
2013 ST1300 A9
000679
2570
On the ST1300 / ST1100 the distance collar is a good pressure fit against the inner race of the bearings. The tightening of the wheel axle makes it so. If you try to install the bearings with a bit of a gap between the spacer and the bearing, then when the axle is tightened, it will draw the bearing in using the centre race, which puts a lateral load on the bearing, which will cause it to fail prematurely. It is important to drive the inner and outer race together when inserting - and stop when the bearing meets the collar.
This makes extracting the first bearing a bit of a pain. The collar is difficult to budge if you are using a drift for the first few taps. But with the axle out it can be shoved to one side - both ends the same. One the bearing has moved, it will rock out of the way quite easily. Remember to tap both sides of the bearing by the same amount, otherwise the bearing will jam.
I couldn't believe how much easier it was to get a bearing out with the proper tool though.
Years ago, before I got the correct tool, Once I had removed the distance spacer I filed two small notches in one end that helped me to get the edge of drift onto the inner face of the bearing - ready for the next time. But bear in mind that distance spacer takes the entire load of whatever the torque setting is for the rear axle - so thinking back, I am not sure that was a good idea. Others may wish to chime in on this point.
The correct tools make it easy. I did a video a few years back using the proper Honda tool - but the same sort of tool is available from other suppliers.
I didn't have the complete set of correct tools for replacing the bearings at the time, so I was making do. Link
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
Like John, I ground two recesses in the ID of the distance collar, on opposite sides, for a drift to catch the bearing inner race. On the ST1100 rear collar put the recesses for the drift on the left, single-row bearing side... the right side, double-row bearing is best left to be removed after the left one and the collar are out.
I have the official Honda Special Tool for wheel bearing removal... doesn’t work worth a ****. BTDT. The STOC free loaner wheel bearing R&R tool kit has slick custom made wheel bearing removal tools for both ST1100 and ST1300: http://www.st-riders.net/coppermine/displayimage.php?album=21&pid=976#top_display_media
To borrow the kit (register):
http://www.st-riders.net/index.php?topic=1343.0
It’s been used successfully many times by fellow STriders.
