This week I've replaced 7 secondary master cylinders that were all completely frozen solid!
3 were police motors, with 60,000 to 80,000 miles, and the other 4 were civilian models with very low mileage 20,000 or less.
So today, between calls, I spent the day cleaning them, and taking them apart for inspection.
4 of them had the piston frozen/rusted at the beginning of the bore, 1 was out of the bore a bit, and 2 of them were jammed half way down the bore.
The last two stranded motor officers in the middle of an intersection and were unable to be moved.
In the model years 2003 - 2007 the spring(s) behind the plunger measured 22 mm, 25 mm, 28 mm, and 30 mm (these were the old style units with the spring trapped on the plunger).
In the model years 2009 - 2012 (the new style longer/narrower spring with the hockey puck on the spring ) were found 32 mm, 35 mm, and 40 mm in length.
Seems that whenever these things start dying, binding, and starting to stick in the bore, also causes the springs to take a set where ever they get stuck, and then remain there.
Just one more thing to think about when your brakes start binding.
