Thanks. I'm glad I asked.
I thought it might sound like a dumb question.
Last December I replaced the SMC (thanks @Igofar!) with a whole lotta help from the White Courtesy Phone.I am a little confused about what part number I need for the 2009 model.
Again, I want to replace the entire assembly, but it's not clear which part number is the correct one for the 2009.
Thanks in advance!
Thanks for that. For anyone who may have difficulty reading the above image, the correct part number for 2009+ SMC replacement is:Last December I replaced the SMC (thanks @Igofar!) with a whole lotta help from the White Courtesy Phone.
Mine is a 2008, which is after Honda's modification from the earlier-model's SMC. Ordered from Ron Ayers -- use this part number (EDIT: the R02 suffix reflects the newer p/n):
@Sadlsor has provided the correct part for models from 2008 onwards.
Make sure your bike IS the 2009 model that you think it is, and not a pre- 2008 model that was registered late.
The white label on the frame under the pillion seat tells you and the 10th character of your frame VIN should be a 9 for a 2009 model.
Dont forget to buy plenty of crush washers for the banjo bolts. Many of us buy copper from on-line suppliers at not much money per unit.
And they are directional....
The sharp flat edge of the washer must be against the banjo fitting for proper seal.
Appreciate you posting the part number. I'm sure it's in a few dozen spots on the forum, but searching secondary master cylinder yields roughly 4.7 thousand threads. Also worth noting, in case it helps someone else's search:Whoops-that would be 06454-MCS-G03. I discovered that the 5 was actually an S after I cleaned my glasses.
Thanks for the help.
