Gents -
Sorry this took so long...but read as to why....
I ordered two units from radiorider.com, and my main goal with these was to use them as an intercom; as well as to listen to music. My secondary need was to be able to use the phone if necessary.
Fit/Finish - 9
I have to say...The units look SLICK! Quite small and unobtrusive; and lightweight yet there is a feel of quality. They fit my helmet nicely (HJC CL-33 and IS-33), and tuck close to the helmet skin.
The rubber sealing flaps that fit over the headphone jack and charging jack are well made, and fit snugly...However, I have not had a chance to use these in a downpour, so I cannot comment further. The Gold-plated contacts are nice, and give me some comfort that oxidation will not become an issue.
Ease of Use - 7.5
There are definitely pros and cons of only using two buttons to control everything. On the plus side, you can do absolutely everything with gloves on quickly. Button pushes give a positive feel. On the flip-side, sometimes it is hard to figure out what mode you need to be in, as there is a brief switching delay. So wanting to jump from music to the phone and back sometimes can be frustrating...It would be nice if each function had a different 'beep' to audibly let you know where you are at.
Audio Quality - 9
The only reason why these units do not get a 10 is due to the physics involved of having an open speaker in a helmet. Perhaps with the earbud clamp (more on that later), they would get a 10. I can say that:
-Music sounds fantastic. Not audiophile by any means..but come on..its a helmet.
-Intercom works great. As stated above, you need to pause a second or two for the units to cycle and connect but duplex audio quality is excellent, and has been tested at over 90mph.
-Telephone usage. I will only comment on audio, as actual functionality varies way too much on phone hardware. I had phone conversations without any issues while in a 50mph cruise.
Bluetooth - 10
The units sync to themselves and anything else that I have tried stupid easy. I sync'd to other units, my phone (HJC TILT), my laptop (toss it in the 'bag to stream MP3's), and my Nuvi*.
*- more on this below
Battery Life - 11
Yes - 11. Both units have been in use NON-STOP for over 7 hours before the battery gave up the ghost. This means mixed intercom usage, and constant music streaming. The units charge quickly...Truly amazing !
Only one Issue:
-One unit I had initially received was defective. If I was listening to music via the headphone port and switched to the intercom, I could still hear 'staticy' music...Like the unit was not switching completely. I contacted Sena with the problem, and they sent out a completely new unit the next day; no questions asked. You cannot ask for much more than that !
*My Nuvi 265T would only sync one way. In other words, I cannot use the Nuvi to make phone calls; using my Sena as the headset. I need to direcly link to the phone, and use voice-to-dial, instead of the Nuvi's screen. This is an issue with the Nuvi I believe; not the Sena...But worth mentioning.
Overall - 10
What I like the most about Sena is their customer service, and willingness to bring new products. See:
http://www.senabluetooth.com/index.php?tab_menu=acc.
The nice thing is if you want to use earbuds, you don't need a whole new unit - just get the clamp. Have multiple helmets - just get a new clamp. They are under $30 IIRC.
Fit/Finish - 9
Ease of Use - 7.5
Audio Quality - 9
Bluetooth - 10
Battery Life - 11
Only one Issue:
Overall - 10
