That is the procedure from OEM manual for tensioning a new belt, to get the correct tension. As you cranked it 4 times, you could feel the resistance for turning is different as the pistons go up and down, cams opening valves etc. I guess the 3-teeth thing aligns all internal components in a sweet spot, where the tension is most "correct" engineering wise. I was also wondering if it is the biggest, the weakest, or somewhere in the middle But that's just my theory.While I'm in there .New Timing belt installed this evening . One thing that I don't get is : Tightening the tensioner pulley .Clymer calls for cranking the engine 2 or 4 times _check marks -then moving it 3 teeth further - before tightening Tensioner Pulley bolt to 46nm . 3 teeth further, what is the point of that ?
I followed that when I swapped mine a month ago. So far it runs good (in the garage), will test out on the road in spring.
