Can you read any of the Vehicle Id. Number stamped into the side of the steering head of the frame?
Can you read any of the engine number that is more or less on the bottom of the crankcase?
An "ST1100A" is an ABS model, but an "ST1100 A" is a non-ABS model built for the American market that excludes California. In other words, the A in "ST1100 A" stands for American, not for ABS.
I think you said you have "the" shop manual. But there are three. The Clymer has a chapter on engine removal. The Haynes was done on a complete teardown of a pre-1996 ABS model, known as ABS I.
If you have a 1995 or earlier ABS model, I have one of those and also a non-ABS model to compare. I know most of the differences. And yes, the ABS I is pretty complex. It has the coolant reservoir moved off of the frame and onto an engine guard. It has metal rear brake lines, not rubber.
And if your frame is a post-1995 one, I would never attempt what you're doing. Those STs have non-standard brakes. For me, life is too short to mess with such.
I think you said "the" ST1100 was your dad's favorite. There's no such thing as the ST1100. Do you have any info at all on what version of ST1100 your dad had? What year? Did he mention ABS? (Many people like ST1100s just for the engine, drive train, and handling.)
Thanks, and good luck to you.
One of the anniversary editions (25th or 50th) is a Gold. Very nice in my opinion.Ok, so have got pretty much everything now to make a complete ST. Am going to see if it runs properly before disassembly.
Does anyone have any colour suggestions for the respray? Should I stick with a traditional colour or go crazy with Ninja green, etc?
Also, if anyone has a suggestion regarding the reassembly please let me know.
This might help. Read the post as they detail some errors on the videoDoes anyone know what tools are needed to check the various engine tolerances beyond feeler gauges ?
Thank you KiltmanThis might help. Read the post as they detail some errors on the video
Valve check/Adjustment video ( ST1100 ) *
Valve check/Adjustment video ( ST1100 ) *www.st-riders.net
Bike Quip sells a swing arm protector. I installed them on my ST1100's and my ST1300.Dose any one have an opinion on this as well as extending the inner fender, near the swing arm, with rubber or some other material?
Waxoil the cavities, you know it makes sense.Major Project! Good luck with it.
I started with a complete 93 1100 non ABS this winter and at times get overwhelmed.
At the moment I am wrestling with whether or not to seal the voids in the Swing Arm fabrication
Prior to painting.
That is do I calk them shut or let well enough alone?
It is surprisingly rust free and I want to keep it that way.
Phil, you're checking the right stuff but does the kill switch kill the lights? If it does, is it "on"?Well,
Didn't take long to find the first issue.
Battery freshly charged but no dash lights or power when the key is turned.
It doesn't appear to have had the red wire bypass done so my guess is that part of the wiring harness is fried.
After fuse checks can anyone suggest potential causes or what to look for please?
There's no headlamp with the bike but have one in a box with some other bits n bobs. Will connect it up and let you know.Phil, you're checking the right stuff but does the kill switch kill the lights? If it does, is it "on"?
Upt'North.
