St1100 only runs on half choke
british columbia
St1100
2026 Miles
000000
Last ride of the year I had turn signal switch problems so I took off left hand cluster, corrected issue and put back together. This spring I went to start it and when I move choke beyond half choke or give it throttle it dies. I suspect it's an issue with choke lever on the handlebar, but i've had it apart about 4 times and cannot see any kinks or other issues. Also somehow I inadvertently failed to fill the tank and it wintered with only a quarter tank. Looking for ideas/suggestions. Thanks.
I suggest you add a good quality fuel injector cleaner, for a few tankfuls. This will get most of the gunk out of the carbs.
I’m confused, it doesn’t run with full choke? Or it can only run with half choke
