Article [13] ST1300 - Brake Maintenance - Photos of dismantled SMC
Do not be tempted to check behind the rubber boot of your new one. It is extremely difficult to be certain that it has been refitted properly.
Agree. In comparing my reassembly attempt with the new SMC I did not seat the boot as deep as the new boot is.
I have never removed the boot but I filled it with silicone dielectric grease to fill the void to help dissuade moisture ingress. I haven't the foggiest idea if it makes any difference or not but my SMC is still the original from 2009 and it still works as it should.
There's nothing wrong with removing the boot to do that - although the boot itself makes a perfectly adequate seal if it is not disturbed. The problem is that if the boot is pulled out, the 'brim' of the top hat shape does not seal by itself when it is replaced. It requires some effort.
The image below is taken from a more detailed explanation here.
The problem is getting the brim of the top hat pushed in beyond that angled step. It wants to rest in the wider part of the bore and feels as though it will not go any further. I found a driver from my socket set which would fit inside the alloy opening and the top hat rubber boot would fit inside.
You are pushing a sprung circlip into a hole that is too small for it. The angle on the face of that hole - the angled step - is just about enough to squeeze the circlip into a smaller shape. Imagine doing that with the circlip in hand with fingers. The angled step will squeeze the clip to the right size, but it requires a hefty shove. A bit of silicone grease will help around the brim. You cannot mistake it when you feel it push into place. But you can convince yourself that it is fitted properly when it isn't.
I undid the bracket - the one that you are not supposed to undo - in order to do this. I measured the length first. Funny how you are not supposed to undo it, but it has instructions to apply thread lock and gives a torque value !!
I keep meaning to find some tubing of the correct diameter and cut it to length and saw it vertically in half so that I can wrap it round the top hat and use that to push the brim into place. A bit like fork seal drivers. I'll do it if I ever need to remove the piston again.
Photo is the pre-2008 version.
It is important because if water gets past that boot, the air side of the matser cyclinder is open to air and water - it can get through the hole int he washer through which the push rod passes. Once in there it can corrode the bore, which stops the piston from returning properly and that serious rear brake lockup due to the piston not being able to move past the tiny compensation port.
More silicone grease inside may help a little bit, but its not going to stop it.
The drain hole is to get rid of any rain water pooling around the brim. I guess that if you can poke a soft probe through that drain hole (pre-2008) and see it from the plunger bracket end - then the boot is in the right position. If the probe meets the rubber, then it isn't.
When I got the ST1300 I was already aware of the SMC water ingress problems that plagued the design. Beyond liquid water I figured that area could possibly also house moisture laden air that will condense later on and leave liquid water sitting in there. I considered it a bad design in general in that it should have been orientated with the vulnerable part facing down. Since I couldn't change that I decided filling the void leaves no where for gaseous or liquid water to accumulate. It was not difficult to do and did not require removing or disturbing the boot in any permanent manner, so I pumped it full of silicone grease as I couldn't really think of a serious down-side to doing so. As stated, I have no idea if it helps or not or if I would have had the exact same service life without ever having done so.
The only problem that may be caused by that is the grease can break down, turn into liquid and seep past the seal and contaminate the brake fluid etc.
I have found many SMC’s that were compromised by the owner’s spraying things like WD40 in there thinking it would help.
Just a thought/concern.
I considered that before doing it. The dielectric grease that I used is pretty inert and it can be used as an assembly lube during assembly of brake components. Even if it did find its way in to the brake system it will do no harm so I have no concerns over that. Things like WD-40 would be asking for trouble and would probably result in it.
