Hey All. I was wondering; why is it that the battery will drain to a point it won't start the bike if the headlight is left on for a few minutes? I had Yuasa check mine at Americade and they said it was fine but while in GA, the guy who put the LED directionals in the mirror left my key on for about 6-7 minutes and the bike wouldn't start. What Gives???
Thats the capacity of the battery, if you wanted more time you would need a larger battery.
The oem is rated at 230cca and 11.2 AmpHours. You could google the exact details but basically you are looking at 2 different ratings. Cold Cranking Amps is the current the battery can supply for a VERY brief period of time at cold temps when the battery is not able to provide as much current. IOW starting the bike under bad conditions.
The second number is the capacity of the battery to provide current under light load conditions for a longer period of time. More or less 1.2 amps for 10 hours until the battery is exhausted. This is not a linear relationship. The battery would not deliver 11.2amps for 1 hours. It would be derated. The higher the load the worse it gets.
You wouldn't want to drain the battery to that point it's designed as a starting battery.
(High current short period of time) A battery that provides power over time is constructed differently, called a house or deep cycle battery. The trade off is it can't provide the high current for short periods of time but can stand up to the abuse of draining the battery better.
You can't compare it to a car as a car battery is MUCH larger but the load of 2 headlights and tail lights is similar to a motorcycle load with the engine off.
