Sudden gas leak?!?
Afan
Afan
... and this is my real name.
Urbandale, IA
1998 ST1100
8832
Hey Afan. Stuff some clean rags into those intake ports before you drop something in there!
Good one. I was rushing myself to take a picture before of the hoses before removed...
Thanks.
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
I doubt this is the source of your problem. The only way any gas is going to leak there is if one or more of the float bowl drain screws is not fully seated. Are they...?
Afan
Afan
Urbandale, IA
1998 ST1100
8832
Hi John,
That's good point.
I can't check right now because the bike and carbs are at friend's shoppe, but I plan to work on my bike tomorrow and I'll let you know. I didn't plan to rebuild the carbs but I will do some cleaning.
Afan
Afan
Urbandale, IA
1998 ST1100
8832
Last night disassembled and checked all 4 float bowls - they were (almost) perfectly clean. O-rings are in good condition. Float bowl drain screws are also good.
My bet would be on a carb float that 'sticks' open then unsticks itself. Or could be a piece of trash stuck in the mechanism somewhere. IIRC, the ST1100 floats are hollow. See if one of them is pinholed (fills up with gas in use then empties while sitting). Just some guesses.
+1
afan, while you're in there make sure to check the floats for any leakage. And, a very tiny piece of debris can get stuck between the float needle and its seat and prevent it from sealing. pull off each float/needle and inspect the tip of the needle for any debris. Then check the seat that it fits into and make sure its clean too.
Las Vegas, , Nevada
94' 1100 ABS
I had a similar issue. When I sat on the bike it put pressure on the line , or the clamp, to the fuel filter and somehow leaked. When not on the bike it did not leak. Once the fuel lines were changed, clamped, and re-routed, the problem was fixed.
Afan
Afan
Urbandale, IA
1998 ST1100
8832
I'm ordering parts. Can somebody please check my post on this thread and confirm I picked correct items?
Thanks.
Afan
Afan
Urbandale, IA
1998 ST1100
8832
Also, can't find part number for the o-ring on drain screw. I want to replace them too.
P.S. What the number 1 in the square box means?
it means you get both the o-ring and the gasket with one part number, so that answers your other question about the o-ring part number as well.
Afan
Afan
Urbandale, IA
1998 ST1100
8832
I was assuming that but couldn't find the #1 item to make the order. Look
http://www.partzilla.com/parts/search/Honda/Motorcycle/1998/ST1100+A/CARBURETOR+COMPONENTS/parts.html
http://www.ronayers.com/oemparts/a/hon/5053e751f870021c54be2bc7/carburetor-components
But, it's here
http://www.procaliber.com/oemparts/a/hon/5053e752f870021c54be2bcb/carburetor-components
:D
Thanks!
Wasaga Beach, Ont. Canada
'04 ST1300 Blue STar
In researching the need to replace the upper to lower fuel tank hose on my ST13,,, I found this photo. Then I ordered the hose and clamps !! Cat'
paulcb
Celina, TX
'97/'01 ST1100 ABSII
8735
Wow, I've not seen that pic before. Looks like an ST1100. Is there a story behind that?
I believe the story was,,, that you should replace the inter-tank (between upper and lower) connection hose,, every time the tank is tilted for service. This seems like a lot,,, but I guess there were incidents,,, and my fsm does indeed say that. In my case,,, I don't know the age of the hose,,, or if it has ever been changed at all. My tank has now been tilted up for about 3 months, while I do winter maintenance. Given that the hose may very well be deteriorated,, cracked and age/heat hardened,, even though it looks good,, better play safe this time around. Cat'
paulcb
Celina, TX
8735
I meant the story behind the burned ST1100. ;)
