Tony, firstly congratulations on the ABS job
. In a County Durham sort of way.
Secondly you state the NM at 5000 rpm, I thought electric motors provide constant torque from 1 to whatever is possible.
Thirdly you don't need the gearbox, you only need to retain the output shaft and drive shaft. I agree it makes a lot of sense to retain these but the gearbox won't be light and weight will be your enemy here. Whilst not easy (understatement) if you could connect the motor by gear or chain to the output shaft then you will only need space for batteries and controller. Thankfully there's lots of space in there for everything and I'm guessing you will be mounting the batteries as low as possible.
Good luck. I think the ABS job will turn out easy compared to this.
Upt'North.
Upt'North.
