I do that sometimes.
A. There goes your wet clutch, which will slip badly with friction reduction additives.
B. There goes a substantial portion of your motor power driving that extra machinery.
C. There goes a substantial portion of your weight and volume capacity for batteries.
I think you'd be dropping a much smaller amount of weight than you're thinking. On any electric vehicle, minimizing weight and maximizing mechanical efficiency and power storage capacity are paramount.
Plus, leaving that much material in the frame will force you to place the few batteries you are able to squeeze in out of the desired low and central locations and into high and outward locations, ruining handling.
The idea is to get rid of as much of the original drive train as possible, not leave in as much as possible. If you were building an electric bike from scratch, would you look to add half of an engine in the design?
Hi larry ,
really appreciate your thoughts so far ….
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
with reference to your Point A , I didnt think of that , to be honest. I have added it to my other pan but it has not caused ill effects ( slipping ) as yet. Think i might just oil change just in case !
with regards to Point B, not entirely sure on this one. Depend on the eventually selection in EV motor I choose , will have the near enough required torque if not more to the standard st13 combustion engine. As below
standard st13 engine - delivers 118 HP, (86.1 kw) @8000 rpm , 117 nm torque at 6500 rpm.
choices of EV motors so far are :
1. BLDC Motor ( goldenmotor) 20 - 50 kw or 33 - 67 HP , 160 nm of torque at 5000rpm ( suggestions so far , ponder to it being under powered.)
2. BMW X6 HVH250 hybrid motor (ebay) - 63kw or @ 280 volts , max rpm 10600 ( trying to research if feasible.)
3. EV motor 60 kw ( ebay ) , 137nm of torque at 14000 rpm. ( 3 phase , so power would have to huge , so probably impracticable.)
I would like to choose selection 1 , but the I unsure for $1800 USD. the controllers and power for this reaily available. But, it will be an expensive mistake if it is actually underpowered . The OEM assures me it is powerful enough , but I need to do some more research.
The close second at the moment is the item 2 , the only downside is finding the controller for it and working out how to supply a power supply at 280v from batteries.
Point C : I disagree unitl proved otherwise wise the weight. once i strip this whole down and weight it , and then weigh the barrels seperatly , i think i might only save an extra 5 - 8 kg at the most. i can look into this further once the engine is stripped down.
The main weight / COG of the bike will be similar and planned as original, as overall the batteries will hopefully at 4 x 8 kg each( which will be install in the side panniers , will counter the removed heavier mechanical items lower down , such as
- Exhaust and silencers - ( est 40kg)
- Starter motor - ( est 3kg )
- Alternator - ( est 10kg )
- Cylinder heads , cams covers , chain, FI , etc. - ( est 40kg)
total estimated removed weight - approx. 100kg
added weigh being added :
- electric EV motor - ( est 30 kg)
- extra controller system and cabling - ( est 5 kg )
- battery lithum ion car units - ( est 4 or 8 units x 8kg = 32kg or 64 kg.)
the above should hopefully make sense , and describe my thoughts on the lower SOG.
regards
tony
