This is the link that got me started this morning and led to the other two threads. Good stuff.
Click bait. I couldn’t get past the first three.
I put it on 1.75 and 2x speed. And in some cases, just went to the next bike to see what they said. I thought they were actually pretty good on the first one. But then maybe I'm not a real biker.I FF'd through it. I'd be surprised if the author actually rides, or maybe they need to work on their AI prompts, lol.
I didn’t even agree with that one. The chain manufacturer’s grease is sealed inside the rollers by the O rings compressed tightly by the side plates. You’re not going to get grease in there by squirting lube at the O rings from the outside. I do agree that the least aggressive maintenance done to the chain is the best for it. Just wipe it clean, no aggressive brushes, and lightly lube with 80w90 oil mixed with ATF which conditions the o rings and prevents the chain from rusting. Done like this the rear wheel of my chain drive bikes stays as clean as any shaft drive bike I’ve owned.I put it on 1.75 and 2x speed. And in some cases, just went to the next bike to see what they said. I thought they were actually pretty good on the first one. But then maybe I'm not a real biker.
I was very interested in their take on chains in the beginning. It kind of confirmed I'm doing things right.
I would have to agree with you about the chain Dave. If I understood him correctly he said that the "lube needs to get in to the sealed areas" (of the chain). That is when I stopped watching because that doesn't even make sense. If the chain is in good condition the lube can't get in there. That is the reason why the O-rings are there, to keep all foreign matter out of the sealed areas. If the lube can get in to those areas the sealing ability of the O-rings is compromised so I would think that the condition of the chain needs to be evaluated.I didn’t even agree with that one. The chain manufacturer’s grease is sealed inside the rollers by the O rings compressed tightly by the side plates. You’re not going to get grease in there by squirting lube at the O rings from the outside. I do agree that the least aggressive maintenance done to the chain is the best for it. Just wipe it clean, no aggressive brushes, and lightly lube with 80w90 oil mixed with ATF which conditions the o rings and prevents the chain from rusting. Done like this the rear wheel of my chain drive bikes stays as clean as any shaft drive bike I’ve owned.
splitting hairs on this words.....Key reasons for lubricationI would have to agree with you about the chain Dave. If I understood him correctly he said that the "lube needs to get in to the sealed areas" (of the chain). That is when I stopped watching because that doesn't even make sense. If the chain is in good condition the lube can't get in there. That is the reason why the O-rings are there, to keep all foreign matter out of the sealed areas. If the lube can get in to those areas the sealing ability of the O-rings is compromised so I would think that the condition of the chain needs to be evaluated.
I will go back and have a look through the rest of the video because I am not foolish enough to think that this does not mean that there is nothing to be learned from the rest of the video but my immediate interest waned at hearing this.
