st1300 darkside
Monett, Mo 65708
2007 ST 1300
Just got back from a ride with the wife and noticed that my Battlax BT023 rear (on my 07-ST1300) was vibrating a bit in slow turns... yup... cupping badly after 4500 miles. I am so tired of buying tires... I am preparing to go to the darkside... but have a couple of quick questions. 1) My speedo is almost exactly 10% fast (60mph indicated is really ~54mph gps)... will the Hancock 110 help with this? as in, is the Hancock a bit taller (I am hoping so...) and 2) Have any of you running the Hancock experienced issues trying to get the tire balanced? (Did a simple spindle balance work, or do you need to find a shop that will do a professional balance job?) Thanks in advance... James
970mike
Mike Brown
Lompoc, California
07 & 12 ST1300A
SPOT
LINK
8057
James,
I have over 11,000 miles on my Hankook tire and it still looks great. I had the same problem with the 023 rear tire one lasting 5000 miles and the other trying real hard to make it last got 7500 miles. I do like the 023 front tire. The speedometer with the Hankook is just about the same amount off as with the standard tire. I did not balance my rear Hankook tire and have had no problems with it so far. Good luck on your choice of tires.
Mike
Monett, Mo 65708
2007 ST 1300
Thanks for the quick reply! I am reading other threads also... and came up with another question... Did you have to do any mods to the swing arm or sacrifice a chicken to get the tire squeezed into the space? Someone wrote that they had to deflate the tire, install and then re-inflate, but that was with another tire... not the hancock.
Rindge, NH
I, also, didn't balance the Hankook. Some have reported some high speed instability/shake running it (close to or over 100 mph) and I'm curious if their tires were further off than some of ours. Balancing wouldn't be a bad idea, I just didn't have access to a balancer...I can't believe NONE of the dealers in my area have one!
For install, I did it fully inflated. I removed the plastic shield on the right side (one bolt), slid the wheel/tire past, then reinstalled once the tire was past it. A bit tight, but saves deflating and reinflating, especially if you don't have a compressor at home.
No mods necessary. The tire is very close to the swingarm once installed, but it does clear.
Jim
Monett, Mo 65708
2007 ST 1300
Thanks guys!! I am tracking down a tire vendor now... I see that shipping is about 23 bones from just about anyone online right to my door. Not bad, given that the PowerStroke would cost about $25 for the round trip to the tire stores in the big city and then I would have to hunt down the right one. It just pains me that the MC tires just eat away so fast.
970mike
Mike Brown
Lompoc, California
07 & 12 ST1300A
SPOT
LINK
8057
James,
As Jim stated I have no problems without balancing the tire. I run the Dyna beads in the front tire and would have done the same with the rear if needed. I have run my ST to 118 on the GPS with no vibrations what so ever with the Hankook tire. I did deflate my tire to install which was no big deal for me as I have an air compressor. No modifications are needed on the swing arm.
Mike
Bigmak96
R.I.P. - 2021/08/07
Rural Mn
04 GL1800 Past tense
7910
If you have trouble getting your tire past some tight spots try a trick the Wingers use. I see they place a sheet of wax paper between the tire and whatever is in the way and it helps the tire slide by.
Monett, Mo 65708
2007 ST 1300
Checking with my local vendor... they carry Hankook but I don't think they can get close to the e-bay price... still waiting on the reply from the vendor.
970mike
Mike Brown
Lompoc, California
07 & 12 ST1300A
SPOT
LINK
8057
I checked with my local Hankook tire dealer and he wanted $ 115.00 plus tax for the same tire. Easy choice for me.
Grant, MN (aka Stillwater)
ST1100 & ST1300
6145
Guy mentioned at MNSTOC that he used a plastic bag of some sort to make the rubber tire slide right on.
Vernon BC, Canada
2007 ST1300
8025
The tire sure looks great. The problem I have is every spring the bike seems to have grown an inch and touching the ground is getting alot harder.
The only time I'm flatfooted is with two up fully loaded.
My question is - does this tire raise the bike profile? I cannot afford to have the bike any taller.
970mike
Mike Brown
Lompoc, California
07 & 12 ST1300A
SPOT
LINK
8057
The Hankook tire will not raise the bike. You could always do what I did to my wife's bike and replace the rear shock with a Wilbur shock which lowered her ST just over 1"
Vernon BC, Canada
2007 ST1300
8025
The Hankook tire will not raise the bike. You could always what I did to my wife's bike and replace the rear shock with a Wilbur shock which lowered her ST just over 1"
Thanks for the information on the shock. I tried to find their site in the Web but its under construction.
Monett, Mo 65708
2007 ST 1300
ST1100 & ST1300
6145
Just ordered my Hankook for 94 bones delivered to the door!! YES, shipping was included!
http://www.discounttiredirect.com/direct/findTireDetail.do?pc=11189&counter=1&ar=50&rd=17&sw=false&cs=205
I also ordered some tire spoons, rim protectors and just dropped by the cage parts store for some stick on weights just in case. If I cannot get someone to mount it for me, I will be doing it myself. This BT023 with its cupping is coming off soon!
Don't forget about the valve stem if you still have a rubber one. It is a good idea to change them with every tire. At a minimum inspect them but with the long life of a CT you should really look at a metal option if you don't already have one.
