DOH!
I don't have a 1300 anymore... guess I better be quiet concerning them!
Byron-the wheel hasn't been serviced anytime recently. I noticed it last weekend before my ride home from work. I suppose I could try the wipe it down and see if it re-appears method before taking on the task. I'm just afraid to be riding down the road and the front wheel seizes up or something horrible like that.Are you getting any sound or rough feel from the front wheel?
It is possibly just spinning off excess grease from the last time the wheel was serviced. Mine look like that from time to time as I like to use lots of grease. I figure it will keep out water better and I'd prefer a little mess to a rusted bearing.
I'd say wipe if down and continue to ride if there is no noise or roughness in the wheel.
A good set of metric wrenches, metric allens and a torque wrench will prob handle all of NORMAL mantainance... more tools as u get more into the engine ( like valve adjusts, etc )torque wrench. Anything else?
Tom, you've stated the process for left and right pinch bolts and for #3 (axle bolt). Does the 58 lbf-ft go for both left and right axle bolt?never have, as stated the pinch bolts are enough.... Besides, you have to follow pinch bolt/axle routine to make sure the forks align properly ( no pulling to right )... so your going to tighten the pinch bolts and loosen them anyway...re below
(Note: Axle pinch bolts are finger loose at this point)
1. Tighten the left axle pinch bolts to 22 N-m (2.2 kgf-m, 16 lbf-ft)
Note: Indication of “Left” is if you were sitting on bike
2. Tighten Axle Bolt to 79 N-m (8.1 kgf-m, 58 lbf-ft)
3. Tighten the right axle pinch bolts to 22 N-m (2.2 kgf-m, 16 lbf-ft)
4. Now loosen the left axle pinch bolts
5. Note: During the assembly process, this is where you would be installing the brake calipers.
6. Set the bike down where the bike's weight is on the wheels. Lock the front brake and push the suspension up and down several times.
7. Tighten the left axle pinch bolts to 22 N-m (2.2 kgf-m, 16 lbf-ft)
Alright, so I'm going to do the hex set on my post #26, the adapters from V8-7's post #29 and this torque wrench to cover the 5-80 ft-lbs. That should get it done.These are the adapters I was talking about :
http://www.harborfreight.com/hand-tools/sockets-ratchets/4-piece-high-visibility-socket-adapter-set-67925.html
Skip.. I don't believe you can use ceramic bearing for the ST ... wrong type of load/spec requirement.Do think there is any real value to ceramic bearings from CBR Bearings as others have posted about? Are they that superior to OEM bearings? Big price difference? What about the All Balls bearings? Any experience?
Tom Mac's bearing post here.
Only one side has the nut to be tourqued... the other side should fit flush into the left fork.left and right pinch bolts and for #3 (axle bolt). Does the 58 lbf-ft go for both left and right axle bolt?
I thought CBR Bearings only dealt in ceramic bearings?Skip.. I don't believe you can use ceramic bearing for the ST ... wrong type of load/spec requirement.
You ( if needed ) can either get them from many of the OEM parts dealers OR CBR Bearings.
(BTW, the pic of bearing from my thread was the rear flange bearing , not front )
Hey Skip sorry I just got wind of this. Did you get the bearings? I think I have some at the shop but won't be in until a little later. Let me know.When installing the new bearings, does it need to have any type of special lubricant/grease in there with it?
BTW-the fork seals look fine in regards to anything leaking down the backside.
Skip
I haven't yet Tim. I was going to call the Honda shops to see if they have them and how much and then I was going to call CBR and find out how much better theirs are and their price as well. They're on the west coast so I can't call them until 11 or 12.Hey Skip sorry I just got wind of this. Did you get the bearings? I think I have some at the shop but won't be in until a little later. Let me know.
