I think I'm using the 15w-40. autozone and o'reilly carry it.
Thanks
Has nobody ever ridden any other bikes? Yea, my ST gets hot- the whole tank and fuel heats up, especially when at low speeds stuck in traffic. But every engine puts out heat. My Intruder 1500 did (though it had a false tank that didn't absorb as much heat), my old CBR1000 did, my wife's little Ninja does...heck, my KLR tank would get too hot to touch comfortably when stuck in traffic. You are sitting with a 1300cc, 4 cylinder engine between your legs. It ain't gonna be cool!
The t-6 is 5wt oil with a package to thicken it up to 40wt. The standard 15-40 always gets better numbers for me from the lab. I'd say use the dino 15-40.
There has been lots of write-ups of riders putting the heat shielding under the tank and seat area, I got the heat shield under my tank, It helps a little , But the darn drugs the DR. has me on keeps me out of the heat and ridding for now, Better days are coming....
Mike
I mostly agree.. Although it would be nice to vent that super hot air somewhere other than on my junk.I have taken heat readings on several bikes that operate in high heat areas such as Arizona, Utah, Vegas, Yosemite, etc.
the before and after readings with and without the "heat shielding" has always been better without it! Come on folks, you use tin foil to cook a potato in an oven, and that's exactly what your building by shielding things off, your cooking your wires, hoses, and rubber parts etc. Same thing with you remove the inner cowls or drill holes in them, your now blowing all the hot air directly back into the trapped bodywork. Think of putting a fan in the back of your oven and blowing air towards you.
The cowls direct the heat towards the radiator, and allow the coolant system to work, when you bypass it by just blowing it straight back, undirected, you've got no control.
.02
I just bought an '05 ST 1300. During a 4ish hour ride from central Texas to Houston on a day with about 100 F temps, the tank (or air) got so hot that I had to stand up, move my knees around, slide back in the seat, etc. My previous (first) bike was a Kawasaki Vulcan and there was NO heat issue whatsoever, so I'd say that it is not an overall motorcycle issue. This has been a real disappointment to me since I hadn't heard about it before purchasing the ST. The bike has a custom Sargent seat in the lowest position, so there shouldn't be a lot of heat getting through, but it does. I am considering first just putting a towel around the back of the tank to see if that helps. May just end up with a hot towel. May have to remove the inner cowl as I have heard about.
