v8-7
Jeff aka dinkie diesel , wrote/compiled a great trouble shooting guide here
https://www.st-owners.com/forums/sh...ox-CCS-100-Troubleshooting&highlight=audiovox
If your unit passes all those steps, it is probably either the throttle cable is hanging up, but you can tell if that's a problem, because the throttle grip will not snap back, or vacuum related .
When you're blowing into the 3 way check valve , are you blocking the air passage for the airflow that isn't in the circuit ?
I don't recall using a 3 way, just a tee and a seperate check valve ..
