I avoid driving at night , but we have a lot of tunnels here . Driving from daylight into a dark tunnel can be scary as hell ,even if it's short and you see the other side before going in. So my lights got to work the best they can ! I found out my low beam is pointing about 5 meters in front of me -off to the left . High beam seems fine , but I suspect one of the high beams must also point left and down. I stuck my hand in behind the low beam bulb , and felt it was loose. Been reading some threads , and see Honda has their own take on H4 bulbs . SO - I got the shims and now I'm going in ! First question : Should I stick with the standard 60/55w H4 ? They also sell 100/55w H4 here , - but could this cause heat problems (and maybe ruin the headlamp? Second question : Is there any reason not to wire so I have Low beams on both lights ? I'd Like to hear thoughts or know how on this ! Thanks (and I'll get back to exstra lights at a later date)
