- Joined
- Sep 25, 2009
- Messages
- 3,053
- Age
- 68
- Location
- West Des Moines, IA
- Bike
- 2022 Kymco AK 550
- 2024 Miles
- 001353
- STOC #
- 8058
Some of the features of the AK 550:
>Noodoe BT connection to cell phone. Enables custom screens to show in the center round display on the dash. It also include navigation built in with the cell phone app. That center screen also can show alerts from text and phone calls but ONLY when stopped and not moving. I think there is also a locator feature that shows where I parked the bike in a large parking lot like at Walmart using the Noodoe app. That center screen can show photos or custom clocks or speedometers adjusted for offset and weather and other things.
>TPMS is built in, also a voltage meter, and a fuel consumption all built in on the dash display. I think that the TPMS will read pressure without needing to move the bike at all. Some aftermarket systems require the wheels be turning a certain bit before they will read.
>Along with odo, trip meter A and B, there is also miles since last belt change and miles since last oil change.
>It is a Bosch ABS system
>It has 2 driving modes.
>There are integrated heated grips.
>As the photos show it is a belt final drive. The belt miles indicator is actually for the CVT belt and not the final drive belt since that should last a great many miles. We'll see though.
I'll be testing out in the next many weeks how cold the heated grips work for my hands and then I'll decide if I need to install my heated gloves controller. I am fairly certain that when temps get down close to zero F I will need the heated gloves. But it will be nice to have both heated grips and heated gloves working together if that is possible or does any good.
OH, almost forgot. This bike is a true keyless ignition. One photo shows the command dial that turns on the bike and also locks the bike and/or opens the seat to access a large storage space under it. Something to get used to is that the fob has a very far range. I tested this out with one dealer I visited and found that the fob can be almost 50ft away and the bike will still turn on. So I bought a pair of Faraday pouches to keep the fobs in when I don't want the bike to sense them. Steering lock and unlocking the gas cap cover are a few of the functions of the command dial. When the bike is turned off the command dial just spins freely without doing anything so when it's locked and turned off there is no way to unlock or open the gas cap or do anything on the bike. And there are 2 fobs that come with it. If the battery dies in the fob there is a spot on the dash to place the fob to turn on the bike anyway... just like my Rav4 or any other modern keyless ignition vehicle.
The left glove box has a power connector with USB ports, but there is no 12vdc socket. That is something I'll likely be adding to enable me to use my mini compressor if that is ever needed.
A few months ago I downloaded the pdf of the Service Manual as well as a pdf of the color electrical diagram. All for free and in English from one of the Euro country Kymco headquarters web sites.
