sirbike
Correct. They are intended for spoon use. However they work great as protection from the “claws”.Got it, I use a manual tire changer and these are intended to protect the rim from the spoons not to secure the claws on the rim.
Phil, does the mfr offer replacement plastic gripper guards?here's some pictures -
Yes, and I have them but I am looking for a 'better', longer lasting solution.Phil, does the mfr offer replacement plastic gripper guards?
The Amazon ones I posted are for the lower cleats on the turntable. The ones in the previous post are adapters for rotor clearance and Are a little different. I have those as well but have not had issues with them.Mine came with plastic covers but they have cracked and won't stay on the clamps (a slide on fit).
The Amazon ones look 'interesting'.
My machine is a Chinese made Mayflower. Standard Coats tire machine covers fit. They have never cracked or popped off in 110+ mountings. I wonder if something is different on your machine. Your upper cleats look like my lower cleats. The Amazon ones I first mentioned would be worth a try.The issue is the ones that come with the machine just slide on (not very tightly) and there is no way to bolt them on.
And I hate to glue some on then have to deal with the 'mess' when they need replacing.
Time to rip out the cordless drill and tap set...The issue is the ones that come with the machine just slide on (not very tightly) and there is no way to bolt them on.
