I took Larry's advice and used the Valvoline Blue heavy duty 15w-40 and everything works well, although I only have about 1,000 on the new oil.
Rob
Rob
This is a legitimate question. Many people fixate on JASO MA wet clutch certification alone but Honda lists three standards for engine oil use in the ST1300. API rating SG or higher, viscosity 10w30 prior to 2007 and 10w40 2007 and later, JASO T 903 MA. Rotella hasn't carried certification for gas engine use in 5 years.Little confused on your statement of 'don't use the new formula'. How can you tell the difference between the new formula and the old stuff?
Not trying to be a jerk about it, I'm coming up on an oil change and have used traditional 10w-30 for the longest time. If there's something better out there that's cheaper, I'm all for it. Just very confused as to what to get. TIA!
That should be the reverse, 10W40 prior to 2007, 10W30 2007 and later.viscosity 10w30 prior to 2007 and 10w40 2007 and later,
You may or may not be proven to be correct, time will tell. However, past performance is only a good indicator if nothing has changed.To suggest this oil is not good enough for the ST1300 is not rational
The oil exceeds the requirements of JASO T-903. Perhaps there is a conspiracy to defraud the end user. Thank god for internet forums full of people who know more about oil than the oil manufacturers do. Whereby we may all be saved.You may or may not be proven to be correct, time will tell. However, past performance is only a good indicator if nothing has changed.
To ignore the changes in chemistry that have been occurring in automotive engine oils, including this oil, and to not re-evaluate based on the impact those changes may have is equally irrational.
So they claim, but still no certification number.
So, with all that in mind, what specific oil do you recommend?
Something that lubes, but doesn't cause clutch slippage!So, with all that in mind, what specific oil do you recommend?
According to who- Shell through self verification. Generally not considered the best industry practice.The oil exceeds the requirements of JASO T-903.
Having been the one to make this remark does not provide you with exclusion from it, unless you are an oil manufacturer of course.Perhaps there is a conspiracy to defraud the end user. Thank god for internet forums full of people who know more about oil than the oil manufacturers do. Whereby we may all be saved.
