sirbike
I see at least a dozen things that I would go through before riding it
Who on earth put on those Lego style handlebar risers?
A Plate with risers stacked on top as well?
You may want to check/keep an eye on the rubber grommets that are molded inside of the upper tree, as that much leverage will most likely start tearing the rubber out over time, and you'll find the handlebars will start getting loose.
Folks on the great book of face will tell you its normal, "they all do it", but once you open things up and find the rubber cracked/torn, and realize you'll have to replace the entire upper tree, which means removing the ignition and security screws, just to correct it.
Ape hangers on an ST, what is the world coming too?
I am resisting my compulsion to go completely through this bike before I start really riding it.
another DMR cartridge kit
They don't list the ST1300 on their website. How did you get them to do that?
It's great on left turns.I've seen single sided rears before but never a single sided fork like on the red one. How does that handle?
I like your side extensions on your table, good idea.There was some chit chat between Jamie and me while I was putting in an order for my Blackbird. I learned that he does suspension in general.
VFRs is what he was into and got known for so that’s what he advertises. Some other models have been added along the way. He is plenty busy.
I sent my first set of ST forks to have springs and revalve. Big improvement.
Later I sent another set in for the DMR cartridges. Even better.
I got some things done today but the 03 progress came to a halt when the fork damper bolt needed to be impacted out. I’m sure the bolt will go in ok but just couldn’t do that to the next guy.
If that’s not enough incentive, a buddy and I always say “the next guy might be me”.
View attachment 334321View attachment 334322View attachment 334323
