Re: 1300 Screen Mod
I quickly made a pair to try out. What a difference. I was able to ride with the windscreen below eye level and almost eliminate wind noise. The loudest noise was tire noise. I was able to listen to my Zumo with my Edsets without maxing out the volume.
I made a second pair using 1/8" x 2" aluminum bar. I used 1/4' bolts with nylock nuts. Should have used a little smaller bolt but I had a 1/4" tap. I drilled and tapped the bolts and used red Locktite to keep them in place. I used a textured paint in an attempt to match the texture of the black plastic under the windscreen. I got some pooling of paint at the bottom on one side, when I flipped them over and painted the other side, I used some bolts as spacers so I didn't get pooling. Still not dry enough to put on the bike yet, but here is a photo of the texture.
