1250fa chain!
czarwolf
Kingsland, GA
2011 Suzuki 1250FA
I was using Dupont chain wax and degreaser, But i think it was seeping thru the O-rings and running off my natural lube. At the moment using some Wallyworld wax based chain lube while i shop for a cost effective replacement, I live on a dirt road and do 400 miles a week for work alone, not counting weekend adventures.
Obo
East Coast Canada
'03 ST1300A
I have used kerosene for years to de-grease the chain first, which is fine on it and the o rings.
While it is the least expensive option it's not the easiest and quickest which is why I prefer the maxima cleaner :)
Don-STOC237
STealer
Western Nevada
Suzuki GSX1250FA-ST
237
I quit using chain waxes, of any brand. IMO, they hold dirt and grit on the chain and promote premature wearing of both chain and sprockets. They also collect into a nasty greasy chunky mess inside the primary chain cover. I've had the best luck with Amsoil sprayon chain oil. If I can't find that, I use Dupont chain oil with Teflon.
czarwolf
Kingsland, GA
2011 Suzuki 1250FA
You are technically right, which is the best kind of right! [Just ask a lawyer :p ]
While Kerosene is safe on O and X rings, It does seep past the rubbery rings and gets rid of your precious oil / lube and such! This information was given to me from a Fortnine video on which chain lube is the best.
czarwolf
Kingsland, GA
2011 Suzuki 1250FA
This stuff? If so its still wax based but just with Teflon. My last bike was a shaft drive so i am still new to chains :p But this is what i was using on my last chain, the one i just replaced.
Obo
East Coast Canada
'03 ST1300A
If you do a lot of dirt road riding you'll want to clean, check and lube the chain frequently regardless of what product you use. On my old Honda Nighthawk I used 80w gear oil as per the manual. It smelled bad and flung worse - but it worked.
czarwolf
Kingsland, GA
2011 Suzuki 1250FA
I do about 3 miles of dirt road riding every day, I live at the end of a dirt road, beyond that its 1 mile of paved road and 58 miles of highway every day.
Don-STOC237
STealer
Western Nevada
Suzuki GSX1250FA-ST
237
Obo
East Coast Canada
'03 ST1300A
Im still looking for the chain on my ST1300...
The self adjusting drive chain is enclosed in the final drive tube and submersed in a combination cooling / lubricating fluid. It helps keep any contaminants from getting on it. You just need to change the fluid on a regular basis.
Here's what's inside the rounded tube..... The cush drive attaches to the left side bearing on the arm.
The rounded outer tube holds the cooling/lubrcating fluid and make everything look pretty.
:nuts:
Spokane Wa
2007 ST1300
:nuts:
Oh OK NOW it all makes sense to me.....
