This opens a can of worms. Yes, you can steer a ST1300 by simply shifting your weight but at speed you simply aren't able to make the bike turn very sharp and it doesn't work on winding roads unless they are interstate in nature.As a kid I grew up riding a bicycle everywhere. I quickly learned that I could let go of the handle bars and just peddle. I could turn the bike by leaning and bring it back straight. It was much more comfortable to sit straight up than be bent over the handle bars. I only touched the handle bars to stop with the hand brakes. It all becomes muscle memory and subconscious. On the ST I never let go of the handle bars, but I have a very light grip. I STeer the bike with my rear end by weight shifting and letting the weight shift turn the handle bars. My hands just follows what the bike does. If you are pushing and pulling on the handle bars you are working too hard. As the video shows the bike will steer itself by caster, weight and balance.
Hey Shuey, speaking to the statement in bold I think when riding at speed you are are actually using two counter steering motions to initiate and hold a sustained turn. The first push of the right grip (or pull of the left grip) off sets the bike and rider to the right from the path of the vehicle and sets the motorcycle into a right hand turn and the second counter steer is the push on the left grip to stop the increasing lean and thus sets the radius of the turn. If you could be magically lifted or removed from the bike it would continue the right hand turn on it's own accord. But back to the right hand turn... when we clip the apex of the turn we "pick the bike up" to exit the turn by a push on the left grip to lessen or stop the right hand turn and bring it to vertical.Fascinating video . . . thought provoking for sure.
I'm not sure it is fully applicable to motorcycling though. It translates well at low speeds, but I'm skeptical how well it applies at higher speeds.
At slow speeds, my motorcycle rides just like shown for a bicycle. Counter-steering, turning momentarily a little in the opposite direction, to set balance followed by steering in the direction desired works just fine to make the turn I want. However, as speed increases I reach a point on the motorcycle where it seems I'm only counter-steering throughout the entire change in direction.
Turning, whether on a bicycle or a motorcycle is so intuitive I'll be paying more attention the next time my wheels start rolling.
I'll look forward to following this thread for possible additional discussion and insights.
Thanks Larry!
Shuey
I rode a bicycle a lot, too, but while I could coast hands-free, I could never learn how to pedal hands-free.As a kid I grew up riding a bicycle everywhere. I quickly learned that I could let go of the handle bars and just peddle. I could turn the bike by leaning and bring it back straight.
I, on the other hand, steer solely by counter-steering, and my weight-shifting follows.On the ST I never let go of the handle bars, but I have a very light grip. I STeer the bike with my rear end by weight shifting and letting the weight shift turn the handle bars. My hands just follows what the bike does. If you are pushing and pulling on the handle bars you are working too hard. As the video shows the bike will steer itself by caster, weight and balance.
I discovered counter-steering by myself after three or four years of riding without realizing it.A light grip on the handlebars is exactly what you want to have and pulling or pushing on the grip to counter steer through winding roads and tight S curves doesn't normally take much effort at all - it's normally barely perceptible. Many riders don't even know they are doing it - pushing the right grip to initiate a right turn. So a light grip is essential. We want to know what the front contact patch is doing and locked up wrists, elbows, and shoulders shuts down all feedback from the front wheel's contact patch.
Yes, the overall design of the bike has everything to do with how it handles. Some are oh so sweet and others not so much though careful attention to suspension adjustments can tweak steering geometry and help a bike steer better.I discovered counter-steering by myself after three or four years of riding without realizing it.
But the ease with which a bike responds to steering pressure depends on suspension set-up, especially that which affects steering geometry.
The California Superbike School put out a video a few years ago using a modified "No B.S." (No Body Steering) bike that demonstrates the need to counter-steer.Try riding in a straight line while shifting your weight off to one side. You must counter-steer.
That will for sure screw things up. After a while we steer unconsciously, bringing it to the forefront often confuses what to do and how much pressure is needed.Turning, whether on a bicycle or a motorcycle is so intuitive I'll be paying more attention the next time my wheels start rolling.
I went decades without a ride and bought my 11. Not really very smart! But, after a few k's, we found a way to get along! Learned a ton from vids!Enjoyed the video. Returning to riding after a number of years off and re educating myself. The ST has enough bulk to highlight when I get things wrong and there is a lot of intuitive, that is to say stuff I didn't know I was doing, and counter intuitive stuff, things that feel wrong even though they are right. Videos like this and Mc rider, Fort Nine, Bret Tracks etc are great. Obviously, you don't want to over think it...but I learn better when I understand the detail. Thanks
If the rear suspension height (easiest single geometry adjustment) is set correctly for my weight, the steering torque required to lean the bike and that required to bring it back up are just about equal.At the statement counter steering all the way through the turn, I’d check that by asking, are you applying pressure to counter the the geometric induced tendency for the bike to stabilize upright.
