Happy New Years eve. I'm going to change the fluids for clutch and brakes, and would appreciate links or brand / model for bleeding tools. Is there a particular model, or kit thats popular? Thanks.
Ha! Very funny! Thank you .Motion Pro speed bleeder, only way to go. Vacumes suck...... See what I did there...??? Ha! T
Thank you sirepairMotion Pro Mini-bleeder wrench: https://www.motionpro.com/product/08-0482
Mighty-vac or similar vacuum bleeder. Most auto parts places, and Harbor Freight carry them: https://www.harborfreight.com/brake-bleeder-and-vacuum-pump-kit-63391.html
Thanks Erdoc48I’ve used SpeedBleeders over the past few years for the brake calipers and the clutch slave cylinder and they work very well for me. Just another option of course.
I would suggest using the standard motion pro bleeder over the wrench style, as the wrench style uses a rubber grommet that wears out quickly and renders the tool useless.Motion Pro Mini-bleeder wrench: https://www.motionpro.com/product/08-0482
The wrench style also is unuseable in some applications where clearance prevents rotating the handle.I would suggest using the standard motion pro bleeder over the wrench style, as the wrench style uses a rubber grommet that wears out quickly and renders the tool useless.
The standard one uses 3/16-5/16 clear tubing you can get at any hardware store.
I have this one- about the best available but you need an air compressor
Thank you jonjonboo.I have this one- about the best available but you need an air compressor
Thank you Igofar. Reading jfheath article.I would suggest using the standard motion pro bleeder over the wrench style, as the wrench style uses a rubber grommet that wears out quickly and renders the tool useless.
Thank you oldbikefixr.View attachment 267100
I use the Motion Pro bleed valves, with a longer hose on the output end that I cut for the ST's. Just don't unscrew your bleed fitting more than necessary or it will suck air and leak.
Thank you Andrew ShadowThe wrench style also is unuseable in some applications where clearance prevents rotating the handle.
I am considering one of these. One thing I wonder is how fast the "draw" is on the system. The other thing is all the components involved that seems like a bunch of overhead. I should probably look for a youtube on the operation.
[/QUOTE
That's a bit more than I'd like to spend, but thank you STPaulK. I saw this one there as well. https://www.amazon.com/gp/aw/d/B00265M9SS/ref=psdcmw_15707321_t1_B0015POUXM
The rubber grommet is supposed to provide an air seal, according to the manufacturer. Does the standard size have a way to prevent air going into the system at the point of contact with the nipple. Thanks.I would suggest using the standard motion pro bleeder over the wrench style, as the wrench style uses a rubber grommet that wears out quickly and renders the tool useless.
