TPadden
Tom Padden
..... and I'll take the opposite view, unless he agrees with me, then I'll rethink my position, and take the opposite :.Mac, I'll take yur view over anything I've read on the web.
Sorry, but meant I honestly didn't mean to cause any of this.Riiiiiiiiiiiight......you were probably cackling like a mad scientist as you hit "submit thread".
Thanks George. Those videos definately show why I went with the CT. I will admit, it takes just a bit more to get it leaned over than a M/C tire, but it takes all of 15 seconds to get used to that part and then it's business as usual.Playing both videos side-by-side, it's obvious the MC tire puts less rubber on the road in upright, straight line conditions while the car tire puts down at least as much in the corners.
The latter. And as I said it is a minute amount more pressure on the handlebar. My driveway is 22' long. The first stop sign is 60' away from the mouth of my drive and by the time I got to the stop sign, I had the additional 1/2 ounce of pressure required mastered. A new set of tires on the same bike requires less pressure to lean than an old set that have flattened in the center of the tire.There is something telling in the oft repeated comment "it handles and turns just fine once you get used to it". I have heard or read the comment in practically every discussion on the subject.
Just what do you have to get used to? Does the bike initially resist turning or is the first few degrees of lean somewhat disproportionate to the amount of countersteer that is normally applied to turn a MC tire equipped motorcycle vs the same machine with a CT mounted?
That's what I tell people about the ST.There is something telling in the oft repeated comment "it handles and turns just fine once you get used to it". ..
Thank you sir, may I have another?Tom, ya forgot to add the obligatory <ducking!> to that post. So, here's yur PIE!
If I had said they were synthetic would it have made you feel better???!!!Mac and Gary, I know you meant well in this post but I am now taking an extra dose of Celexa just so I can deal with this thread.
Jeff
"Luke, ..."
<edit> Even better: "Adam, I am your father!"
??? ??? That's pretty much everything I look for in a street tire.You wont see a CT on a moto gp bike because they have exacting criteria that are not needed on the public streets (smooth transitions side to side, superb traction, quick turn in, etc, etc)
Either there was something wrong with the Valk or you just kept dropping it . Seriously I have no problem keeping up with this group:I rode a Valk ona test ride several years ago, grounded both pegs just getting out'a the parking lot! :22yikes:
