And we all know the govt. is always right...
Jim
Jim
Yes they are. I should lead. Then the headlamp mod. would bug me!Hmmmm.... I have Hyperlites on the back of my bike that flash every time I engage the brakes.... is that irritating & distracting as well?
Couple guys I know have a super bright Whelen brake light... that must be even more irritating.
I have a version of the brake light flasher as well. While it might be a bit annoying, its 3 quick flashes, then solid- just enough to catch someone's attention and say "hey, I'm stopping", then it goes solid. I think there is a lot more risk of being rear ended by cagers, and I think the brake lights are more effective than a flashing headlight. I don't ride around with my brake light constantly flashing. THAT would indeed be annoying.Hmmmm.... I have Hyperlites on the back of my bike that flash every time I engage the brakes.... is that irritating & distracting as well?
Good point, and I was only kidding anyway.Don't break the law.... follow the rules.
I can't speak of anyone but me. Since I ride a motorcycle I have conditioned my mind so I can spot a motorcycle headlight a LONG ways off. The occasions I see a modulating headlight, motorcycle doesn't register in my mind until they are really close.Hmmmm.... I have Hyperlites on the back of my bike that flash every time I engage the brakes.... is that irritating & distracting as well?
I'm actually am fan of these and here is why. They flash for only a limited period of time. This timeframe seems just short enough for my mind to register that I *saw something flicker* and then I look for the flicker and see a solid brake light. In that case, I think they are very effective to spark a brain to seek the reason and note a brake light. I have sometimes thought a short duration pulsing would also be ideal with a modulator. Only a 2 or 3 second pulsing near an intersection to snag the attention. The problem is timing it precisely and that would be too difficult.Hmmmm.... I have Hyperlites on the back of my bike that flash every time I engage the brakes.... is that irritating & distracting as well?
Not "insinuating" anything. Just noting what you said. The modulators can be a distraction.I did turn them OFF when riding the Dragon and similar roads (Twisted Sisters in the Texas Hill Country) since it served little purpose other than disrupting the focus of other riders when they should be focused on the ride.
I like that idea. Sometimes an oncoming car is preparing to make a left turn and you really don't know if they see you until you're right on top of them. I'd like to have a modulator for those situations. As it is now, I'll flash my brights on and off a few times to - hopefully - be noticed.I firmly believe that turning on my headlight modulator as I approach an intersection with a green light is useful.
I don't know if you're kidding or not, but flashing your lights at someone who's waiting to turn is a universal signal for "go ahead".I like that idea. Sometimes an oncoming car is preparing to make a left turn and you really don't know if they see you until you're right on top of them. I'd like to have a modulator for those situations. As it is now, I'll flash my brights on and off a few times to - hopefully - be noticed.
I have used SDC on H4's,,, and Kisan on LED's,,, as far as headlighting goes. Admore rear light bar works well at the back. CAt'anyone suggest headlight and tail light modulator brands
Anything more reasonable than the Kissan?.
My 2001 is set up the same and I use it exactly as Michael does.'ve got one installed on my ST 1100. It's wired so that it only modulates the headlight if I have selected the high beam position.
I have white fog lights mounted low on the front forks and it definitely gets me noticed.What I have seen recently, which I think would be a better solution for increasing conspicuity, is a pair of bright yellow lights mounted low on the front forks. The bright yellow (like a foglight) is unusual and captures attention, and the placement of the headlight at the top middle and the two yellow lights down low on the forks creates a triangular appearance that enables oncoming drivers to judge distance and closure rate to the motorcycle.
1000+ I'm a HUGE fan of yellow lights like the old CIBIE foglight I had. I'd change all amber bulbs to yellow if I could find the bulbs. I had a pair of yellow CIBIE 35 fog lights on my GL1000 below the headlight and maybe 20+" part. Very discernible in a sea of headlights running lights turn signals.What I have seen recently, which I think would be a better solution for increasing conspicuity, is a pair of bright yellow lights mounted low on the front forks. The bright yellow (like a foglight) is unusual and captures attention, and the placement of the headlight at the top middle and the two yellow lights down low on the forks creates a triangular appearance that enables oncoming drivers to judge distance and closure rate to the motorcycle.
