docw1
Bill Rankin
If we're ever riding together, I'll make sure you're in front of me. I think they are as annoying as hell.
There's always some chance that someone will be annoyed at just about anything and road rage is triggered. There have been anecdotes posted here and in YT comments about people who've threatened riders who were using a headlight modulator. It's sad and disgusting such idiots exist and exhibit any confrontational reaction to a device that's 50-stage legal and used properly.If there is any chance a modulator annoys others or makes people think your flashing them out they are more dangerous that not
I saw that a lot in Japan. On some streets that were really well lighted several cars would even be driving with parking/position lights only. I had a headlight modulator on my CB750 and never had a situation were someone thought I was giving a customary double you-can-go flash and acted accordingly. I did have a lot of people telling me my headlight was "shorting out".I mostly turn my headlights down to parking lights
I had modulator on my ST. Any motorist who thinks a modulator is a you-can-go flash is already brain dead and a risk to you. The rate of flashing is substantially higher than you could do manually. Never happened to me, not once, over a 15 year + period I had the ST.............. and never had a situation were someone thought I was giving a customary double you-can-go flash and acted accordingly.
I believe it has to be wired that way to be legal.Mine was set up to be off in daylight and was only on when I turned the headlight to high beam.
Anyone who thinks a momentarily flashing brake light that goes solid is annoying is wound way too tight.I have a version of the brake light flasher as well. While it might be a bit annoying, its 3 quick flashes, then solid- just enough to catch someone's attention and say "hey, I'm stopping", then it goes solid. I think there is a lot more risk of being rear ended by cagers, and I think the brake lights are more effective than a flashing headlight. I don't ride around with my brake light constantly flashing. THAT would indeed be annoying.
But it does give me an idea...maybe I'll wire up a switch to my flashing LEDs so that if I get someone behind me with a modulator, I can start my tail lights flashing until they shut off their headlight modulator...LOL.
Well:I believe it has to be wired that way to be legal.
The criteria used to define low-light condition pretty much equates to dusk to dawn, so basically at night. My guess would be that it was written based on ambient light conditions rather than time of day so that it would also include conditions where it isn't night-time but having a modulator on would be annoying to others, such as in tunnels, or on those days where it is extremely dark and gloomy due to weather even though it is three in the afternoon.(maybe also in low light as Andrew mentions)
Yeah, I mis-read the post. That's what I meant. Although, judging by the link you provided, it looks like it could be on high or low beams? At least, it doesn't appear to say one way or the other.Well:
On in daylight only
Sensor to turn it off at night (maybe also in low light as Andrew mentions)
High beam only
High beam only
It states that motorcycles can have either the upper beam or the lower beam modulated.Although, judging by the link you provided, it looks like it could be on high or low beams? At least, it doesn't appear to say one way or the other.
My error. I was thinking CVC (California Vehicle Code).It states that motorcycles can have either the upper beam or the lower beam modulated.
Correct. I was thinking my CVC.Although, judging by the link you provided, it looks like it could be on high or low beams?
Lol! Of course it states it in the very first line! You'd think that since my line of work often requires reviewing regulations, I wouldn't fall into the trap of not reading the ENTIRE thing but nope, uh-uh, negative Ghost Rider!S10.17.5
A headlamp on a motorcycle may be activated to modulate either the upper beam or the lower beam from its maximum intensity to a lesser intensity ......
Who, ME?Well:
On in daylight only
High beam only
There is a lot more to the US modulator found in:
I don't think there's anything that restricts adding an On/Off switch to disable it completely at will as long as all the other requirements are met. Who'd know anyway.
That said SuperSabre had a modulator hooked to LED headlights and the extent of modulation was a 100% On and Off duty cycle. Very distinctive. I don't know that he every got stopped while using it.
Uh at least not by law enforcement.
The US Federal regulations allows modulation of either the high or low beam. Does this California regulation supersede the Federal regulation? Could you be fined for modulating the low beam?My error. I was thinking CVC (California Vehicle Code).
25251.2.
Any motorcycle may be equipped with a means of modulating the upper beam of the headlamp between a high and a lower brightness at a rate of 200 to 280 flashes per minute. Such headlamps shall not be so modulated during darkness.
