Just that I found heat around the ankles increased when I removed the inner cowl. Are your inner cowls installed?Thanks for your insight. Are you able to offer any thoughts on my specific questions?
Paul
Paul
YesAre your inner cowls installed?
I hope that's not the reason in my case as I recently removed the mufflers and gaskets for a tyre change.As for the ankle heat. I read a post where someone found that the muffler clamp was loose and exhaust gasses were blowing onto his ankle. Once tightened ankle heat gone!
While preparing for a TB balance, I found a suspicious item for heat on the left side of the bike.I hope that's not the reason in my case as I recently removed the mufflers and gaskets for a tyre change.
However, since I've only had the bike for 4 months, I have nothing to compare it with in summer. I am fairly confident that's not the reason as the aluminium frame is very hot to the touch as was mentioned in the article referred to in this thread.
Paul
I found a suspicious condition while getting ready to do a TB balance that may have something to do with heat. The disconnected line should connect to #1 TB.I hope that's not the reason in my case as I recently removed the mufflers and gaskets for a tyre change.
Paul
I've dug out my thermometer for measuring temperature on metals. So tomorrow I intend to ride for about 30 minutes and measure the temperature at various points on the bike. Will report back.I found a suspicious condition while getting ready to do a TB balance that may have something to do with heat. The disconnected line should connect to #1 TB
Moses2, I took my bike to the Honda dealer yesterday to have the throttle cables replaced. At the same time I asked them to check for any leaks from the exhaust system.While preparing for a TB balance, I found a suspicious item for heat on the left side of the bike.
