- Joined
- Dec 1, 2018
- Messages
- 63
- Age
- 64
- Location
- France - SW - Pyrénées Atlantiques
- Bike
- ST1300 - 2004
Use a pair of long handled needle nose pliers, come from below and behind to get at those hoses to and from the oil cooler.Thanks a lot @Igofar
Have you any tips for the procedure to set new hoses, specially the one going to the oil coolant radiator at the back of the engine ?
Hmmn, I was able to remove and install the new hoses with the needlenose pliers. I think I probably swabbed a tiny amount of silicone grease inside the end of the hose.... too long ago to remember. I remember I did not have to remove the shift lever mechanism.@dduelin, with long handle neddle nose pliers, I succeded to remove the hose but to connect the new one I don't, i am impelled by the lever of the gearshift selector
Use a bit of anti seize inside the hose and it will slip right on. Ask me how I know, @Igofarmay be the part of the branches who are perpandicular to the handle, 3 cm on my pliers are too short, I will try again tomorrow with some silicone at the end of the hose;
thanks a lot dduelin
Just my personal preference, but I don't use any kind of lubricant, anti-seize compound, penetrating fluid, oil, grease, etc., that is petroleum based as a lubricant for installing any kind of rubber or synthetic material unless I know for certain that it can not damage that material. A product like anti-seize will not disappear. It will remain in contact with the hose for years going through thousands of heat cycles with an unknown effect. I know many people do it without issue, but I see no reason to experiment and find that one-off combination that rotted my hose.about anti seize, is a kind of WD40 would be considerde as anti seize ?
it is not from the mother ship but look at this.I'm replacing the coolant hose that runs from the thermostat housing to the oil cooler because it is chaffed through. I checked the parts list to see if the original had a protective sleeve, doesn't. Where can I find the sleeving that mother Honda uses on the coolant lines on the right side of the motor? I have wire bundle sleeving if nothing else.
