What if you don't have the JIS screwdriver? OP didn't. The impact will get the job done. Give it a rest.
You order the correct tool to do the job as he did, then do it correctly without damaging anything.What if you don't have the JIS screwdriver? OP didn't. The impact will get the job done. Give it a rest.
Your now qualified to work at a Honda Dealership Service DepartmentNever could understand NOT using a tool that would get the job done.
Then why say it?I'm just teasing, no disrespect intended.
I would like to do this to mine before it gets difficult to operate. How do you work it into the cable? Are you able to do it from the knob end?Every Winter when I go over the ST, lube cable with a bicycle cable lube from Finish Line brand.
Is this Bob (ACE??)??Bob, did u get the throttle turned down/lowered??? Every Winter when I go over the ST, lube cable with a bicycle cable lube from Finish Line brand.
If U can try steady pressure turning it. That is how I manage to turn it up.
I'd like to know this as well.I would like to do this to mine before it gets difficult to operate. How do you work it into the cable? Are you able to do it from the knob end?
I have looked under the headlight and can see the adjuster. I tried turning with screwdriver and felt like I was applying more force than I would have liked. But it did turn. Seemed to me that I could control a socket on the adjusting nut better than a PH screwdriver. Needed an extension for my socket set, which I just got....so, I'm going to give it another try.I'm working on that light adjustment for you. have U tried turning with screw driver???
The idle adjuster is on the right side of the engine just above and in front of the cylinder head. No tools are normally required to adjust the idle speed.the idle is screaming high, have tools, i just don't know where the adjustments are??
:: would it be too much to ask for video's or at least jpeg's, the internet is my only resource, thanks in advance.
This is probably the post that @Bmacleod is referring to: Excessive Idle on cold start up. Hopefully there might be some useful information there.... @CYYJ has a write-up somewhere on his throttle body Re and Re where he has pics and a description of the tube/cable design
Hi Kev:The idle adjuster is on the right side beside the valve cover. It’s a black knob with a philips (jis) screw in the center. Use a screwdriver to adjust it.
The knob is locked in place when pulled out. You must press “in” before you try to turn it. When you’re done, pull “out” on the knob. Its easier to turn if you turn the throttle a little first. Make sure your engine is at 3 bars before you adjust.
Bingo, I was half right ... no pics but that write up was what I remembered reading that clued me in to how the "cable" works. Good explaination
Good information Michael. I initially turned the knob, but was advised to use the screw. Good to know either way works.Hi Kev:
It appears that there is a lot of misinformation here on the forum about that idle adjustment cable - with various folks, some of whom I highly respect, advising that you need to turn it with a JIS screwdriver, or turn the knob, or describing other "special" ways to operate it.
When I had my throttle bodies off (the cable is part of the throttle body assembly), I had a really good look at it. I ordered a new adjustment cable, replaced the old one, and took the old one apart. It is a single monolithic assembly, more like a flexible rod than a "cable" - it is not a Bowden cable in which a small cable within a sheath rotates. So it doesn't matter what you twist - the knob, the outside of the cable, or the screw - the whole damn thing turns. That is probably why it is so susceptible to fouling - if anything is pressed up against the side of that cable anywhere along its path, it won't turn.
See this post for more information: Idle speed
Michael
