[QUOTE="Nexus, The police versions need the risers so that the right switch doesn't hit the tank.
[/QUOTE]
It still hits the tank ☹
[/QUOTE]
[/QUOTE]It wouldn't if you had your handlebars as ridiculously high as I have on my '01:
Really? I replaced my risers with Heilbars almost immediately but I don't remember the switch hitting the tank.It still hits the tank ☹
Crazy! Did you have to modify/extend the wiring/tubes?It wouldn't if you had your handlebars as ridiculously high as I have on my '01:
The Helibars were already on the bike, lowered to suit the previous owner. I raised them all the way, and they reached the new height, only requiring taking off the brake hose clamp under the lower triple clamp.Crazy! Did you have to modify/extend the wiring/tubes?
It still hits the tank ☹[QUOTE="Nexus, The police versions need the risers so that the right switch doesn't hit the tank.
Your upper triple tree grommets are torn/damaged and are pulling out of the aluminum from the added leverage of the risers etc.It still hits the tank ☹
Grommets are tight, how long should the tube part of the bars be?That makes me wonder if someone replaced the longer police handlebar with a shorter civilian bar after an accident?
Or it was used for rodeo's and the squatted and lifted the bike up with the bars, which destroys the grommets.
Not sure you understand about the grommets and what they do.Grommets are tight, how long should the tube part of the bars be?
If this was the case, wouldn't the gap between the switches and clutch/brake reservoirs be smaller since the police versions are longer? In fact, I'm not sure the right switch/throttle would even fit. It's pretty tight on that side.That makes me wonder if someone replaced the longer police handlebar with a shorter civilian bar after an accident?
But if my grommets are worn out, wouldn't I get a lot of movement in my bars?Not sure you understand about the grommets and what they do.
The only way you would know if they were damaged would be to remove all the bar mounts and stuff and inspect them.
The NUTS may be tight, but the bolts are a long shoulder, short thread type thing and would just tighten against the shoulder and stop etc.
It’s the long center of the shoulder that is levering the grommet out or damaging them etc.
As the other person mentioned, your plastic housing is not centered correctly on the bar and that may be causing your issue as well.
Look for the assembly set up dot on the bars for the correct position.
No, think of a hockey puck with a small hole drilled through it, then a metal shaft the same dia. As the hole going through it.But if my grommets are worn out, wouldn't I get a lot of movement in my bars?
