The running light(white) is cancelled out when the indicator is used
I went searching and found this information from the original supplier of switchback bulbs
This confirms what @T_C & @ST Gui mentioned earlier but the info in italics is interesting
There are two styles of switchback bulbs: 1. AO - Amber - Off 2. AW - Amber - White |
AO - Amber - Off The Amber -Off (AO) Switchback bulb has special circuitry inside that senses when there is voltage on the (amber) turn signal circuit. Whenever there is voltage on the (amber) turn signal circuit, the bulb switches off power to the (white) running light circuit for 2 seconds. The result is that in most vehicles, the switch back bulb will flash amber-off-amber off whenever the turn signal is activated, even when there is power to the (white) running light circuit. The bulb will switchback to white if the headlights are switched on and the turn signal circuit is switched off for 2 seconds. The bulb will switchback to off if the headlights are switched off and the turn signal circuit is switched off for 2 seconds. |
AW - Amber - White The Amber -White (AW) Switchback bulb has special circuitry inside that senses when there is voltage on the (amber) turn signal circuit. Whenever there is voltage on the (amber) turn signal circuit, the bulb switches to amber mode. The result is that in most vehicles, the switch back bulb will flash amber-white-amber-white, whenever the turn signal is activated and the headlights are on. In some vehicles, the power to the (white) running light circuit is automatically switched off whenever the turn signal is activated. In these cases, the AW switchback will flash amber-off-amber off whenever the turn signal is activated. In most vehicles, the AW switchback will flash amber-off-amber off whenever the turn signal is activated and the headlights/running lights are off.. |
