Just a heads up to anyone in Canada wanting to order Valvoline Premium Blue One Solution - 4l....go to the Cummins site and with delivery 2-4l jugs came to $56
So, Ray... If I let the clutch go, and the bike doesn't move, it would be one or the other possibility.Big Red's got you covered fella.
You cannot go wrong with using GN4.Just to add some oil on the fire...
Today I changed the oil and filter of my ST1100.
Last time I tried Motul 3000. I had no problem with it.
But this time, I decided to go with the "Pro Honda GN4".
Note that the GN4 is the one recommended in the owner's manual.
Price was reasonable at my local dealer : a gallon (just what I needed) was about $40 Canadian ($31 US).
Alright.
Now, to my big surprise, while looking in my Clymer manual (double checking the torque for the drain bolt) there was a caution note... where they say to only use SF or SG, and never use any SH or SJ oils. What ?
In other words, Clymer says not to use the oil recommended by Honda.
Now, to be fair, the owner's manual does say to use the GN4, but also to use an SF or SG.
How come the only GN4 they sell today is an SJ ?
Is it possible that the SJ has evolved, and today's SJ is as good as yesterday's SG ?
From the sticker on the gallon... that oil IS made for motorcycles and wet clutches.
Anyway... I'll see how it goes. In the worst case, I will have to change my oil again.
The Honda manual most likely states to use SJ oil that does not have Energy Conserving, Energy Conserving II, or Resource Conserving listed on the container. With SJ oil it could be just SJ service rated oil, or it could be SJ service rated oil with additional friction modifiers. If it had the additional friction modifiers, it would also have the Energy Conserving, Energy Conserving II, or Resource Conserving (I don't remember the time line for each so I have listed them all) descriptor as well. With SJ rated oils, this had to be listed on the label. One of the reasons Honda called for SJ rated oil for so long after it had been surpassed is because it is the last service rating where the presence of these friction modifiers had to be listed on the label, so there is a means to know if these additives are present or not.In other words, Clymer says not to use the oil recommended by Honda.
Rotella T6 15W40 or 5W40 when they don't have the 15W40. Supertech 6607 oil filter. I just did my 330,000 mile oil change. Oil changed every 10,000 miles since 1,000 on the bike same oil always same filter usually. I did measure my between changes consumption this time, accurately even. I added 9 one ounce jiggers of oil at about the 7,000 mile in point to bring it up to the center of the level hole. So it's using just over none per change. 35 oil changes. Around the world distance 13.25 times on the original clutch and I've saved a grove of oil trees doing the changes at 10,000 mile intervals instead of 3,000 or 8,000.Just curious, what oil are you guys using?
How often do you change your oil? If I'm not mistaken honda recomends every 12,000kms for the st1300. How far do you go on an oil change and how does it look when you change it? Thanks.I’m not recommending any oil to anyone, but when folks ask what I am using, this is what I use….
FWIW @Paulgroovy, I use a full synthetic JASO certified MA2 rating oil and feel comfortable going to 10k kms before changing + oil change prior to winter storage. Works so far for me. YMMV.
And by the way, welcome to this forum from Eastern Ontario
Welcome if I have not yet conveyed this, go back and read the whole 11 page thread and you will find there is no consensus on brand, only specifications(mostly ). Use an oil that meets Honda specs... if you're not convinced, there are numerous oil threads just like this on, there will be another one along shortly as well. Enjoy, happy reading and riding.@Esti1300 thanks for the warm welcome, appreciate it. I see you're a Rush fan. Best rock band perhaps ever.
Anyoo, what brand of oil do you use? I was thinking of using Motul 7100 10w40 because it has the best reviews on Amazon. Then I come here and see some guys don't like it and are having better luck wth HD 15w40 oil for diesels. I have some Motul 3000 10w40 I bought for my Versys 650 I just sold to buy my ST1300. What do you use? Thanks
Well, I haven’t had any problems with that choice in Motul. I have also used Liquid Moly 4T Street 10W40 as well as Maxima Extra 4T 10W40 with no issues. IMHO, Motul provided me with the best clutch feel and responsiveness but only marginally. Just my experience.what brand of oil do you use? I was thinking of using Motul 7100 10w40
Uh, oh. Here we go....FWIW, I’m not aware of any diesel oils that have a JASO certification.
Welcome aboard! Lots of practices and opinions on this board, all right on or pretty near on the mark.
My problem with oil is that modern oils last longer than my comfort zone. I change it with factory recommended weights and brand name JASO-MA2 conforming oils...just read the fine print on the label. I change my oil every 6,000 miles or after 12 months. Plus, I keep an eye on its color weekly, about 10 minutes after a ride,....wipe the lens clean with one of those long foam tipped q-tip style swabs and use a little flashlight. This also gives me a quick indication about oil consumption, so far that isn't noticeable.
Every time I watch the oil pour out into the pan I think 'why am I doing this so soon'. I've considered the factory recommendation but my OCD just won't permit it.
