What bulbs?just did my ST 1100
Wow. The price has gone up $2 since I ordered mine last week.Yes the bulbs from Cindy. http://www.amazon.com/Headlight-Evitek-6500K-Easy-Installed-4500LM/dp/B017M566T4/ref=sr_1_3?ie=UTF8&qid=1451400580&sr=8-3&keywords=EVITEK h4&tag=viglink20849-20
Yes Raymond that's how it works.
This is why I asked if everybody was talking about the same bulb. There's a tendency not to reference what item someone's talking about or leave out important details in a long thread. I know there are at least one or two bulbs that have fans removable from the bulb itself. Even if it's the same bulb from different manufacturers it helps to know what item is being referenced.There was an exchange earlier in the thread that suggested that the fan could be separated from the bulb.
I guess we aren't talking about the same bulb: the G6 H4 from Evitek.I removed the fans from the bulbs.....then installed the bulbs with the clip....
Then slid the boots on....
I agree. I've been trying to make a decision about these lights ..EVITEK G6H4 per the thread title, and still haven't gotten clear info with regards to the use of the boot, and the use of the adapters, as they apply to an 1100.There's a tendency not to reference what item someone's talking about or leave out important details in a long thread.
LOL I wish I could say I wasn't.Or maybe I'm just being dense.
I used no shims on my ST1300. Just cut off the G6 lower two tabs from the base plate, and secure it where the old headlights bulb was located with the ST1300's retaining wire-clip.This mod needs to be done with the G6 Evitek as well for the 1300 so I assume the 1100 needs it too.
I did no modification to my ST1300 boots. After the base plate (less 2 tabs) is installed (without shims), the boot goes on next, then the LED/Fan assembly last.For the G6 the boot on the 1100 would probably need to be modded the same as the 1300 since the fan doesn't come off.
G6 Evitek is what I just installed with the adaptor on my 1300 and I didn't have to cut the boot. I used the adaptor because it lined up the bulb better.For the G6 the boot on the 1100 would probably need to be modded the same as the 1300 since the fan doesn't come off.
Maybe a bit of a heads up for Canadians. Seeing as how Canada Amazon doesn't carry these, I contacted Cyndee and ordered a set.
That was on Feb 20. No sign of them and Chinese tracking is, well......a bit lacking. As far as I can tell, they haven't left China yet. I contacted Cyndee 10 days ago and she said she would look into it. So far, I have heard nothing back. Hopefully they will show up and it was just a one time glitch but maybe hold off buying from China until this gets sorted out or Amazon.ca starts to carry them.
Rod
That is a true statement. The G6 H4 EVIK LED's can be installed with any one of those combinations on the ST1300.Ok so some boots were cut some and some weren't. Some adapters were used and some weren't. I hope that clears everything up.
Thanks for the info. I think that's what I'll do when the time comes.I chose to not use the spacer and not to cut the boot for my installation.
Rob,Thanks for the info.
A guy on the stromtrooper forum had his bulb defective out of the box, but he got them replaced via Amazon itself, not sure why you had to get the China shippingI bought 2 sets of these lights thru Amazon after reading this thread.
The first set went in my ST1300, the second set into my 2004 Toyota Tundra. The bulbs are an amazing improvement over the halogen H4 bulbs, brighter with good cut off. However.....
The tundra required load resistors to work properly. After getting them working, one bulbs' high beam quit working. After a few emails back and forth with evitek, they agreed to ship me a new bulb from China, but only after I cut the wires on the old bulb and sent them a photo of the cut wires.
I am not impressed with their customer service so far.
As I told them in my last email, Rather than waiting for a slow boat from China with only one working headlight, I'll order a new pair from Amazon and have them in 2 days, then send back the pair with the defective high beam.
I only hope the pair that went in the ST has better durability.
