I maintain a maintenance/cost list like this also. And a list of spare parts including where they are if not dangling from my peg-board wall. Helps with planning and keeping things in perspective.Job done and as promised, see costs below.
1990 Honda ST1100 Restore Costs Oct 2023 Description Cost EUR Honda ST1100 1990 600JMP Windshield Bolts 14.95Rear Shock 150Bolt Kit 30Tool Set 30Air/Oil & brake pads F & R 115.95Coolant 9.5Fork Oil 11.95Engine oil 34.5Gear Oil 19.95Fuel Tap Kit 23.95Front Brake Caliper Kit 40.4Fork Repair Kit 36.95Fork Oil Seal Kit 28.95TRW Rear Brake Line Kit 62.95Rear Brake Caliper Kit 30.99Alum. Drain Plug Washers (X6) 2.99Primer, Top & Clear Coat Paints 125Plastic Fillers/Degreaser/Cleaner 25Timing Belt 120Headset bearings 31.95Rear wheel bearings + seals 31.95Front wheel bearings + seals 18.95Clutch Master cyclinder kit 23.95Front brake Master cyclinder kit 23.95Rear brake master cyclinder kit 23.95Clutch slave cyclinder kit 16.95Centre (main) stand 30Front brake caliper bush 11.072X caliper threaded pin plugs 11.08final drive oil seal 15.99final drive o-ring 61x2mm 3.69final drive o-ring 39.5x2.4mm 4.92Petrol tank 52.5Front RHS caliper brake 55Various Shipping 75Total 1944.88Alternator upgrade Cost EUR ACG damper shaft (alternator) 95.94Ball brg (alternator) 23.37O-ring 90x2.3mm (alternator) 11.078x70 bolts 3 of (alternator) 7.38Adapter plate John Clark (alternator) 100.22Alternator upgrade fuse box 20Alternator 275Total 532.98Grand Toal 2477.86
